Question about Actiontec Computers & Internet
Actiontec modem no internet light - Actiontec Computers & Internet
Verizon
  • 14 Answers
SOURCE: Actiontec (GS503AD3-01) Modem
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Posted on Jul 11, 2007
Technotch
  • 22 Answers
SOURCE: D-Link Router & Actiontec Modem
connect the Dlink router to the modem ActionTech->( wan port )Dlink. Login to the Router web-interface and go to STATUS & check the WAN IP address which would be modem ip address. if there is an ip address, do ping test on your computer to that ip address and see you are getting successful ping results. If so, the ping yahoo.com and see there is an successful ping for yahoo.
- If there is No WAN IP in STATUS Page, Connect the computer directly to the modem and let me know the ip address you are getting. Can I know your ISP name please?
Posted on Oct 25, 2007
IB4G2008
  • 3587 Answers
SOURCE: Actiontec GT701R modem
what you running it from(computerwise)..sounds like you may have a driver/interface issue with computer.
got backup?
Posted on Feb 19, 2008
  • 11 Answers
SOURCE: I have a Qwest Actiontec modem that has worked
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
Posted on May 07, 2009
SOURCE: Actiontec Modem Won't Work!
Pull out the power plug on the back of the modem, then reinsert it. Should reset the modem
Posted on Jul 23, 2011
How can I disable my actiontect GT704WGR wireless setting? Verizon personnel has enable the wireless setting of my modem actionteck GT704WGR 2 days ago. Now I would like to disable it because I will use...
you can login to the Actiontec modem by typing the ip address of actiontec modem in the address bar of Internet explorer...
It will open the interface of actiontec modem...
In the Interface of actiontec modem you will have option for wireless...
If you look under wireless setting you will be having the wireless mode as 802.11b/g/n or just B/G/N....
Change this wireless mode to OFF...
Thats it you are done...
By default the ip address of action tec is 192.168.0.1
Dec 13, 2010 | Actiontec Electronics (GT724WGR) Retail...
Trying to change from actiontec gt701 to actiontec gt701-wg. after new modem is hooked up, internet light stays red. switched by to old modem and all is fine. anyone know why internet light stayed red?
The reason why your internet light is red for the actiontec gt701-wg is because it is not yet configure. You need to access the gui of this router. enter the username and password for your internet connection. You can contact your ISP provider so they can walk you through for the steps on how to configure your new router.
The old router has green light because it was already configured by your ISP provider.
Apr 08, 2010 | Actiontec GT701WG Router (actiongt701wg)
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
May 07, 2009 | Actiontec (GT701) Modem
Actiontec gt701
Did you Unplug the Modem from Your Electrical Outlet, AND Unplug the Telephone Line coming in too, for 5 minutes?? Give "it" a chance to Completely Re-set/Reboot..I have a GT701 DSL Modem, that's what I did, and it worked fine. "IF" that doesn't work I would go to "Support" at either Action-Tech or Your DSL/IP Provider. Hope this Helps you.
Feb 27, 2009 | Actiontec (GT701) Modem
take a wire and carefully touch it to the two attachment points of the copper ring on the left side while it is plugged in. I first froze my system for 15 min then thawed out and touched the wire as instructed and all works fine.
To open the box remove the clear soft contacts on the bottom, should be four. Using a small philips remove them and pull the box in two. Then fix according.
Hope this helps
Aug 27, 2008 | Actiontec (GT701) Modem
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | Actiontec GT704WG Wireless Router...
got backup?
Feb 19, 2008 | Actiontec (GT701) Modem
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Jul 10, 2007 | Actiontec (GS503AD3-01) Modem
Computers & Internet Logo
26 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
