Question about Panasonic DMR-ES35VS
Vhs The VHS is stuck in the machine an error code of F06 is coming up
  • 1 more comment
  • Anonymous Dec 06, 2007
    We have the exact same problem. VHS tape tries to eject then stops.
  • sailorica Dec 24, 2007
    OK so our tape just couldn't get out of video recoreder, Panasonic NV-FJ618 model.
    when we finally got it out, our video recorder refused to accept any more tapes. not a single one.
    what shall I do?
    thank you very much
  • fairmargo Jan 24, 2008
    yes, same problem F06 error message - tape acts like it will eject, then doesn't. Any fix?
Full power down fixed ours
Posted on Dec 19, 2007
How to remove a cassette stocked in a vhs machine?
If the VHS tape is stuck inside, and when you push the eject button, it wont come out. Then you need to unplug the VHS player, take it apart so that you can access the inside. See how the tape is stuck inside and start to take it out the best you can. Once you get it out you may have to throw away the tape if it is messed up badly, if not wind it back up. Put the VHS player back together once you get the tape out. Then try to play another VHS tape and see if it works again. If not, it may be a bad VHS player or it may be the tapes. Hope this helps. I have had to take mine apart to take a tape out, so that's how I know
Feb 12, 2015 | Televison & Video
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Daewoo VHS to DVD converter - disk only plays on the converter
The Disc needs to be finalised. Using the setup menu and disc info you select "finalize disc". I had the same problem.
Jan 12, 2009 | Daewoo DV-T8DN VHS VCR
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Vhs stuck - plastic roller part floting inside case.
You could probably do it yourself, but it would be best if you got professional help, you know, just in case if you don't know where the part went.
Oct 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Panasonic DMR-ES35VS Logo
300 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
