Question about Microsoft Xbox 360 Console
X box 360 fault
My console froze turned it off and now i cant get no picture or sound cant be major as it is still lighting up green
  • 3 more comments
  • Banchee Nov 12, 2007
    I have had my xbox 360 for less than a year only played it for 2 months and now when it turns on the picture doesn't show just fuzz but the sound is fine?
  • Anonymous Dec 03, 2007
    my xbox 360 has sound but no picture
  • Micky160982 Feb 15, 2008
    similar, mine played fine, then picture fizzled out and now it boots up fine with green lights, but no picture at all coming through to the TV.
    I turned off/on at plug, let it cool down, removed scart wires and put them back in, still no further forward - is it the xbox thats goosed! or maybe the connections to TV? ive never heard of connections going tho!
  • granty02 Apr 27, 2008
    thats exactly what happened to mine except i get sound
  • Anonymous May 21, 2009
    my x box froze up i turned it of now i have no sound no picture with green light and red ring
  • 27 Answers
Its has to do with the mother board it probly got damaged after it forze so you will probly need to get it replaced
Posted on Oct 09, 2007
Do not wrap your xbox360 up in towels it just fucks it up more even though it seems to work your actually doing serious damage...
All of the mentioned video problem have a greater repair success rate when the GPU is reballed. The same goes for some of the more stubborn game freezes. I've reballed the GPU on 10 console and only one could not fix GPU, it was probably damaged when the customer overheat it doing the xclamp reflow.
Reballing is not cheap but it does work. It's the best solution to the 3RLOD, all though professional reflowing will repair most problem, there still the issue that the solder balls under go numerous temperature cycles making them brittle which will also require a higher temperature to reflow them. Note that the xclamps must be remove to prevent any re-occuring 3RLOD's. That being said any existing system that does not have the 3RLOD should be removing the xclamps as a prevent measure. I'm in the process of putting together a tutorial which allow the removal of the xclamp without drilling or adding bolts to fix it. It use's all of the exsisting hardware with no modification needed to remount CPU and GPU.Please not that this method will only work with systems that have been reflowed or do not have the 3RLOD.
Posted on Dec 03, 2007
Same happened to me so i wrapped it up in 2 towels for 15 minutes and it worked again....... for 20 minutes
Posted on Oct 10, 2007
SOURCE:
When i turn on x box 360 the green center light appears but the four side lights to not ( no ring). I can open and close the disc on x box but nothing shows up on the tv.
Are your controllers connected to the xbox? that is how you get green light bars around your main green light bar. If you are not refuring to this and nuthing is showing up on your tv screen but you have sound try ajusting/ spinning around the yellow av cord ( Yellow cord is what projects pictures onto screen) . Hope it helped. =]
Nov 03, 2010 | Microsoft Xbox 360 Console
When I try to turn on my xbox 360 my controllers do not connect to it. I get the green power light on the front of the xbox 360 and four flashing green lights on my controller. I have tried my...
Press the circle button in front of your xbox 360 and at the same time press the small circle button on your controller ( located near the port where you connect the play and charge kit cable) so they can sync with each other
Sep 16, 2010 | Microsoft Xbox 360 Console
I have no picture, but no red lights
It's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
This is a serious issue that will need the attention of a skilled Microsoft tech. Contact Microsoft asap.
Jul 11, 2009 | Microsoft Xbox 360 Console
3 red flashing lights
When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply is button is red than you need to replace the battery or check the connections.
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. If you are experiencing this problem, you can submit a console-repair request online.
Hopefully your system is still under warranty.
For step by step troubleshooting directions please read the attached link and Happy Gaming!
http://support.microsoft.com/kb/907534
Oct 17, 2008 | Microsoft Xbox 360 Console
When i turn my xbox 360 on i get a blank screen with no picture or sound
My solution would be to send it to microsoft if it's still under warranty.
Aug 28, 2008 | Microsoft Xbox 360 Console
My xbox 360 is not displaying any picture just sound
its overheating but will give u red light eventually try googling X-Clamp fix i fixed many with same problem
Mar 21, 2008 | Microsoft Xbox 360 Console
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
408 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
