Question about Vtech Lands Phones
How to remote answer to answering machine - Vtech Lands Phones
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you didn't give the model of your VTech system, please enter it into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Posted on Jun 22, 2014
Answering machine Model 25865. Is there any way to turn the answering machine "on" remotely. Example: while away, electrical storm causes machine to turn off. Is there any way to remotely...
The manual for this phone doesn't say you can turn the answering machine on remotely, but every one I've ever seen can do so. Most of them say call your number and let the phone ring...and ring...and ring, and eventually the answering machine will turn on. Ten rings is what I've seen most often. I guess the manufacturers figure most callers will hang up fairly soon if the machine doesn't answer, so they pick a large number. Try it on your phone; worst that can happen is it won't work.
Jul 09, 2011 | Uniden Cordless Phone
How to operate the answering machine
hi friend,
Step 1Call your telephone number and wait for the answering machine to answer. If you have left the answering machine in the off state then you should let it continue ringing until the machine finally answers, this may be as many as ten rings or more. When the machine finally answers, you may hear a series of beeping sounds.
  • Step 2Press "0" during the playback of the greeting message or during the series of beeps. Enter your PIN code within the next 2 seconds. You must know your PIN code to operate the answering machine remotely.
  • Step 3Wait for the prompt to enter a command code for remote operation. You will hear the machine report the current time and how many messages are in memory. The machine will then play a beep and wait for your command. To turn on the answering machine you must enter the corresponding code. You must enter the remote command within 15 seconds.
  • Step 4Hang up after the machine finishes the command and beeps. Call back to your number and make sure that the machine is now in the on state and will answer incoming calls.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Each brand and manufacturer of answering machines have different commands and PIN codes for the answering machines. Refer to your user manual for the exact codes and instructions on how to pick your PIN number for your phone.
    hope this helps u
    please rate me.......................
    thank u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | Panasonic KX-TG2343 Cordless Phone
    Remote turning on of answering device
    I'ld consult your owners manual orgo to RS's website and get a PDF version
    Jun 23, 2009 | Radio Shack 3822 Digital Answering Machine
    Lost my manual and cannot remember how to get messages remotely
    Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
    Remotely Operating Your Answering Machine
    Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
    To continue playing your messages, press [#] then [2] again within 15 seconds.
    To operate from a remote location, use any touch-tone telephone and follow these steps:
    1.) Call your telephone number and wait for the answering machine to answer
    2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
    How to enter a PIN
    To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
    Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
    Enter a two-digit security code (00-99) using the number keypad [0-9].
    Press the OK soft. You will hear a confirmation tone.
    The answering machine announces the current time and the number of messages stored in memory.
    You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
    Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
    # then 1 Repeat a Message
    # then 2 Playback Messages
    # then 3 Skipping a Message
    # then 4 Deleting a Message
    # then 5 Stop Operation
    * # then 6 Answering Machine On
    # then 7 Memo Record/Stop**
    # then 8 Greeting Record/Stop**
    # then 9 Answer Machine Off
    # then 0 Help Guidance
    Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
    Remote answer machine turn on
    Most Uniden answering machines will turn on remotely after the 12th ring. Call your home phone and just let it ring, ring, ring.
    Apr 09, 2009 | Uniden 5.8GHz Cordless Phone
    How to retrieve messages from the answering machine ..remotely
    Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
    During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
    The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
    Apr 01, 2008 | Uniden TRU9488 Phone
    Remote answering
    you have to set the answering machine to accept remote access. Then anytime when you call home and the message is playing you can enter the machines' remote access number to retrieve your messages.
    Dec 13, 2007 | AT&T 1738 Digital Answering Machine
    Lands Phones Logo
    15 people viewed this question
    Top Vtech Lands Phones Experts
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
