Question about Frigidaire Dehumidifiers
Clean filter on frigidaire dehumidifier - Frigidaire Dehumidifiers
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Frigidaire 50 pint dehumidifier freezing up and
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Posted on Jul 13, 2010
  • 4736 Answers
SOURCE: I have a 2 year
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Posted on Jul 20, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: I have a frigidaire LAD704DUL 70 pint dehumidifier. Last year it worked great. This year, it has not collected any water in the bucket. The motor runs, it is on CO setting but still no water. I have c
    If you have a dehumidifier that is not producing any water then you are wondering what you need to do to get this thing to work for you. In some cases you may be able to do something and in other situations there may be nothing that you can do.
    If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
    A few things that can cause this are:
    The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
    The compressor has failed...if you hear a buzz for a few seconds, every few minutes, then you have a bad compressor or at least bad start components on the compressor. Either way it again is a costly repair.
    If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
    If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
    If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
    If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
    Also if nothing is running check the float switch or the bucket switch. Many of these switches are very touchy and if you do not have the bucket in place just exactly right it will not trip the switch to allow the unit to run. These switches often are more fragile then they should be and break easily. The good thing is that when available they are easy to replace and relatively inexpensive.
    There are some parts available for a few brands, but with the prices for most of the parts that you can replace running anywhere from 40.00 - 80.00 dollars, replacement parts with labor to install them, makes a repair more then the few hundred dollar cost of many of these dehumidifiers.
    As you can see there are quite a few things that can cause your dehumidifier not to work. Systematically go through the list and eliminate things to get to the bottom of the issue causing your problem and then decide if it is worth spending the money to try to fix the old unit. Only you can make that decision.
    Posted on Aug 14, 2012
    Frigidaire FDL50s1 runs continuously but will not collect water. What could be the problem & can it be fixed?
    Thank you for your post, K!
    I understand that your Frigidaire dehumidifier is continuously running and it is not collecting water. This can be caused by a dirty filter. A dirty filter can restrict air flow which will allow your dehumidifier to not pull in air. I would recommend checking your filter to make sure it is clean.
    Frost on the coils within your dehumidifier will also cause your dehumidifier to stop working as well. You should check to make sure that there is not frost visible on your dehumidifier. If you do locate frost you would need to perform a manual defrost on your dehumidifier and you can do that by disconnecting power from it for at least two to three hours.
    If these steps do not resolve your issue you may need to reach out to the manufacturer for a proper resolution. I hope this information is helpful to you. -Matt
    Jun 13, 2015 | Frigidaire Dehumidifiers
    I have a Frigidaire Dehumidifier, Model FAD704. the Clean Filter lights keeps coming on and the unit stops running. The filter is not dirty. I take it out and put it back in and unit runs for awhile and...
    Hello Winl, thank you for your inquiry!
    I see that you are having issues with your clean filter light coming on in your Frigidaire dehumidifier. From what you are describing it sounds like a possible issue with a sensor within your dehumidifier. I would recommend consulting with your manufacturer to see if they can provide any additional assistance towards a resolution. Best of luck! -OOS
    Dec 12, 2014 | Frigidaire Dehumidifiers
    What should I do when the air filter light comes on?
    Good Afternoon Friend, that's a great question!
    Typically the FILTER RESET light will illuminate after 250 hours of operation. To locate the filter, remove the bucket and the pull filter downwards. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions. Hope this helps! - Z
    Sep 11, 2014 | Frigidaire FDL50R1 Dehumidifier
    Removing the filter model fdl7051
    Hello Friend, this is Z. Thank you for allowing me to assist you!
    You would need to remove the bucket to locate the filter of your Frigidaire dehumidifier (FDL70S1). Then pull the filter downwards for cleaning. The filter can be clean by using clean water or vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once you reinstalled the filter then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier should resume normal operations. Remember it is best to clean your filter every two weeks based on normal operating conditions and typically the FILTER REST light will illuminate after 250 hours of operation. Hope this helps!
    Aug 12, 2014 | Frigidaire Dehumidifiers
    When turned off, makes a humming sound which it never did before. Can I ignore or do I need to fix some?
    I understand your Frigidaire dehumidifier, model# FAD704TDP, is making a humming sound, when it is turned off. I also see that you have tried cleaning the filter and grill already, and want to know if there you should be concerned about this. You should not be alarmed by this. Providing, your dehumidifier is doing what it is supposed to do, and is taking moisture from the air, your appliance sounds like it is working fine. Hope this is helpful.
    -Best Regards-
    WP
    Jul 08, 2014 | Frigidaire FAD704TDP Dehumidifier
    How to locate and replace internal filter?? For frigidaire
    I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
    a. Remove the filter every two weeks based on normal operating conditions.
    b. To remove the filter, remove Bucket then pull filter downwards.
    c. Wash the filter with clean water then dry.
    d. Re-install the filter, and then replace Bucket.
    I have also included the link for your manual, where I found these instructions. Hope this is helpful.
    -Best Regards-
    WP
    Frigidaire Manual Search Results
    May 30, 2014 | Frigidaire Dehumidifiers
    How to clean the filter
    Good Afternoon Tad, thank you for allowing me to assist you!
    First remove the bucket to reach the filter of your Frigidaire dehumidifier, FAD504DUD. When you locate the filter, pull it downwards. The filter can be clean by either washing it with clean water or using a vacuum cleaner extension hose. If you use clean water, please allow the filter to dry. Once the filter is reinstalled then replace the bucket. To extinguish the light simply press the FILTER button and your dehumidifier will resume normal operations.
    Hope this helps!
    Jan 31, 2014 | Frigidaire Dehumidifier Fad504dud
    Hello , I have goldstar dehumidifier model #DH40 . It's freezing from back grill? Can you please give me some solution to it? Thanks for you're help
    It sounds like not enough air flow. clean the filter. I would suggest unplugging it and let it set for a day to dry out then replace filter and clean the air path including coils.
    Jan 10, 2014 | Frigidaire FAD704DUD Dehumidifier
    Dehumidifier smells stinky
    Have you read its manual? http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0220en.pdf
    It says (p8):
    Care and Cleaning
    1. Filter
    d. Re-install the filter, then replace Bucket.
    2. Cabinet
    a. Dust cabinet with an oil-free cloth, or using a damp cloth.
    b. Vacuum grill using brush attachment.
    3. Water Bucket
    a. Clean bucket with warm water and detergent.
    I recommend you to use a mix 75% water, 25 % vinegar. To clean its water bucket.
    Oct 01, 2012 | Frigidaire FDF70S Dehumidifier
    Dehumidifiers Logo
    35 people viewed this question
    Top Frigidaire Dehumidifiers Experts
    Charles T Nevin
    Charles T Nevin
    Oloyede Monsuru
    richie46
    Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
