Question about Dell Inspiron 1545 Notebook
White screen virus
When i turn on computer, only white screen appears. nothing loads. no errors. no noise. sd rom doesnt run. when i attempt safe mode unable to access command prompt to try ad manually ru cd rom
    Top Expert:
  • Dell Master
  • 21,532 Answers
Sounds like no GPU. With the hard drive, RAM and battery removed, plug the power in and press power, It should load to bios. If it doesn't, there is a GPU issue. If it does, you will soon know what the issue is.
Posted on Nov 21, 2013
4 Suggested Answers
SOURCE: Red vertical lines appear, can only run computer in Safe Mode
check the video cable and see if it;s properly seated. run the laptop with something that uses memory. if the video chip it going to show signs of problems, it will be more prominent when the laptop gets hot. most cases laptop motherboards have integrated video cards and cannot be replaced.
Posted on Aug 27, 2007
  • 998 Answers
SOURCE: Will not boot to Safe Mode
Try to boot from the Resource CD by selecting the <F12> key and select boot from CD/DVD drive. If you tried to run the "Diagnostics" option from the <F12> boot menu and it went to command prompt, there might be an issue with your hard drive or the "Diagnostics" partition is corrupted or missing. If all tests pass using the Resource CD, then your OS is probably hosed. As for the 9 LED light, that just indicates that your numeric keypad is enabled.
Posted on Oct 17, 2008
leecom72
  • 4806 Answers
SOURCE: Blue screen of death
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
Posted on Jan 26, 2009
I install windows xp profetional in g62_b39se it installed compeletly but when insatll completed, an blue screen apeared whith stop massage
Power on Laptop & Click F8 Button then Safe Mode Menu Visible Select "Disable Restart After System Failure" Then U Wacth And Reply Error Msg And Error Code Fully.
Best Of Luck
May 07, 2011 | Computers & Internet
Everytime I open my open my computer this error loading winppw32.rom appears.
Its a virus. Go here:
http://www.freedrweb.com/cureit/?lng=en
download CURE It and save to a usb stick or similar
Reboot the computer in safe mode (F8) before windows loads
Run Cure IT, let it do a simple scan then a full scan
Dec 25, 2010 | Computers & Internet
Every time, the windows is loading, i got that error message "error loading winiio32.rom the specific module could not be found"
Heya
winiio32.rom is a not a system component.Unfortunately its a trojan(virus) commonly know as Vundo which directly infects your registry of the computer.It also disables all the anti-viruses,firewalls and all the other security features in the computer.In worst case scenarios it also disables .exe files.
Now in order to fix this problem you can do some following steps-:
Turn the computer off
As soon as you turn the computer on start tapping the F8 key repeatedly.
Now select safe mode with networking with the arrow keys on the keyboard.
Now the computer will boot in safe mode and you might see a black background with icons appearing very big but don't freak out its normal in safe mode.
Now i would recommend you to download Malwarebytes-:
http://www.techspot.com/downloadget.php?id=4716&file=1&evp=0a59f9584bb65ce60f8292a3fc06e555
Now as soon as you download it install and update it and run a full scan.It will definitely pick a lot of infections.Click on remove infections and restart your computer.
90% of the times this will fix your problem but as i dont know how severe your problem is for example-the virus might have disabled .exe files or might have put restrictions in the computer which will not allow you to open any .exe files nor you can end the the process of the virus which is still running in the background as it will also disable task manager.
So do let me know if these steps fixes your problem.In case if it doesn't fixes your problem we will try the next steps.Don't worry we will definitely fix this problem.
Thanks & Regads
Long LiVe tHE gEeKS!!!!
Dec 08, 2010 | Computers & Internet
Blue screen error
The most frustrating blue screen computer errors are basically caused by some physical faults such as faulty memory, power supplies, overheating of PC components, or hardware running beyond its limits, device driver conflicts etc.
If you see the blue screen and halts occur in boot process, and also notice some specific error message appear on your screen, this indicates a serious issues most probably due to inappropriate device driver or firmware .Blue screen is really an annoying issue and creates a lot of trouble to the end user.
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Aug 27, 2010 | Microsoft Windows XP Professional SP2
Computer will not re-boot
your hard drive has been corrupted due to improper shutdown
Oct 07, 2009 | Dell Dimension 3100 PC Desktop
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Black screen with mouse only
there are several things which might resolve your problem.
attempt to get into safe mode (with f 8 at boot), and check device manager for problem devices.
insert the vista disk and boot, and attempt to "repair" windows, the boot sector particularly. there is usually a "repair" utility on windows disks which allows you to fix problems without completely reinstalling windows.
your computer may be infected by a virus. if you can get into safe mode, try a virus scanner called "avast" if that doesnt work, try "malwarebytes" or "combofix". these can be found by doing a quick google searc, just make sure you download them from reputable sites. you may have to use a seperate comoputer to download the programs.
if you cannot get into safemode, try the same anti-virus software suites, from a different computer, with your hard drive installed in that system as a "secondary" drive. if this is a laptop hard drive, laptop to desktop hard drive adapters can be purchased for around $20.
Dec 17, 2008 | Dell Inspiron 1501 Notebook
Troubleshooting errors
Try starting the computer in Safe Mode.
Then run the anti-virus.
Feb 10, 2008 | IBM ThinkPad 600X Notebook
Aug 27, 2007 | Dell Latitude C640 Notebook
Dell Inspiron 1545 Notebook Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
