Question about Mitsubishi VS-50605 50" Rear Projection Television
I have a 50 vs5051
Turn on stays on for 5 sec. then shuts off??
  • t-rizzy Nov 15, 2007
    I HAVE A VS-50605 MITSUBISHI SOON AS I TURN THE TV ON IT CUTS OFF NO MORE THAN FIVE SECONDS AFTER I TURN IT ON PLEASE TELL ME WHAT THE PROBLEM IS , I TRIED TAKING THE FUSES OUT AND PUTTING THEM BACK IN, IT WORKED FOR A MINUTE LONGER BUT STILL CUT OFF PLEASE HELP!!!!
    Genius:
  • 1,694 Answers
1)Inspect circuit boards for CRT coolant leak! Wet evidence usually on signal board. 2)Possible bad regulator or bad solder connect, esp.regulator output pins. 3)Next? Diagnosis by qualified tech.
Posted on Oct 09, 2007
Unit comes on for 2-5 sec. then shuts down
Probably has lost convergence chips and fuses. But keep in mind--these sets often get a LOT of capacitor problems and fulid leakage problems too--so be aware of this.
Apr 30, 2014 | Mitsubishi VS-50609 50" Rear Projection...
50" lg plasma tv when i turn it on it shuts down in a few sec after doing this several times it will eventually stay on what can i do
The power supply board have problems,it not giving the tv the right votage anymore.That why it shutting down,not sustancening power to the tv anymore.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power board for the replacement.
Oct 16, 2010 | LG 50PC3D 50 in. Plasma Television
When i turn on the TV...it runs for 5-10 min...then shuts off... this turn it back on...it runs again for short time and turns off...repeats several times till it stays on...will stay on indefinitly till...
Hi Friend,
Please folliow the below steps one by one,try by resetting the TV
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
Even after that you are facing the same issue please check with the Display Card whether its has got any problem in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
My panasonic pt50lcx64 will not stay on, sometimes wont even turn on, but when it does, it lasts about 5 min then cuts off and the yellow light blinks 2x every 5 sec
Try typing your model tv along with the words "trouble codes" This could be a code 22 or a 2. Sounds like a bad connection or bad component failing such as capacitor or resistor. The tv may be shutting down as protection against what it senses as a power supply failure.
Jan 08, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
My red and blue crt go out and the green stays on
One or more of the CRT colors guns it dead,must be replaced.
Nov 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Camera doesn't stay on- shut down in a few sec
This is actually a common problem that requires the firmware to be updated. Kind of like software and hardware in one. The manufacture will do it for $50 or you may be lucky enough to find a download on the web.
Oct 01, 2009 | Sony Cyber-shot DSC-H9 Digital Camera
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
