Question about 2wire HomePortal 1800HG Router (1000400229000)
No connection i am on broadband with tiscali through my sagem modem i get a connection.when i plug in my new router through a usb i get no connection so i brought an rj45 wire and used it still no joy.phoned up tiscali and went onto cmd through dos and got some settings but no default gateway what am i doing wrong and would it be a problem with my computer which is running windows 2000. is it compatible to set up a connection.
    President:
  • 2,961 Answers
What you should have bought was a ADSL modem/router, but if you only have a router, try the following:- go to the TCP/IP properties of your network card and ensure that it is set as obtain ip address automatically, restart the pc. Connect modem to the router then connect your router via rj45 cable to your pc, then type 192.168.1.254(This should be the default gateway) into your internet browser to get to the router settings. Look for DHCP and enable it to give your pc an automatic ip address and save settings. You should now have a 100MBPS connection to the router, if you have got a modem router ensure that you have the correct Tiscali settings inputed.
Posted on Oct 09, 2007
BelkinF5D7632-4 modem router with Tiscali broadband intermitant loss of connection. Is the ISP at fault ? Is the router at fault ?
check the connection consistency without the router. Also try varying the time out settings in the router. aka keep alive.
Nov 07, 2009 | Office Equipment & Supplies
Can I Connect my Wii to my tiscali Sagem Modem?
sorry, LAN feeds are one way.the wii should have an internal wireless card for net connections though, assuming you have a wireless modem.
Sep 18, 2009 | Nintendo Wii Console
Problems setting up new macs and a new wireless system with a PC
The MAC address of the network card on the PC is probably registered with Tiscali. The easiest thing to do is to Connect the Belkin router to the internet, then go into the config and clone the MAC address of the windows PC. Once this is done, then you can either plug in the airport express, or configure wifi for the Macs from the belkin.
Jul 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Tiscali broadband wireless connection. Router modems last 6/7 wks then won't connect
Hi, have you got filters on all your phone lines, including  a sky box if using one?
Oct 20, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
ZyXEL adsl wirless modem router P660HW
To bring up the blue screen you need to open internet explorer (or whatever) and type the ip address given. In my book it says 192.168.1.1 after that you should get the blue screen. You can set up the connection then.
Jan 08, 2008 | Zyxel P660HW-D1 Router
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
133 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
