Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung tv no picture white screen - Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Samsung hd 14.2 mp 5x white screen no picture
T-con board has failed. You can replace this board yourself. You can get parts online from here TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 14, 2016 | Samsung Televison & Video
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
White screen
"White screen" on Samsung LED TV - Forums - CNET
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Oct 01, 2015 | Samsung LNT3242H Television
White screen
Hello
White screen with or without sound? If you have sound maybe motherboard or panel (or Tcon module)
Best take it to the nearest authorized Samsung service.
Regards
Apr 10, 2014 | Samsung LA32D403E2 HD LCD TV
White dots all over the screen
White dots are due to bad DMD chip and qualified tv tech can replace required DMD chip in this tv to fix the picture issue.
Please contact nearest Samsung service center or local tv repair shop for repair estimate.
Thanks.
May 16, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
SAmsung has two white lines across screen with no picture
If the 2 white lines are in the centre of the screen it sounds like you have a fault called 'field collapse' . The 'x' or horizontal circuit on the tv deflects the beam across the screen which in your case is ok because the line runs across the screen ok. The 'y' or field circuit on the tv deflects the beam down the screen. Without a circuit diagram for your tv i cannot point to individual components.
Aug 07, 2009 | Samsung Televison & Video
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Problem turn on picture few sec. no picture only clear white and sound
I had this problem and replaced the bulb. I have not had the problem since.
Nov 22, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Jerry Greenberg
Jerry Greenberg
