If I understand correctly you have 15 amp breaker with 14gauge wire.
Total watt capacity of 15 amp breaker is recommended at 80% rated load = 12 amps
You want to connect two appliances to same 15 amp line.
1) You have 6 amp Dishwasher that draws 720 Watts
2) You have under the counter water heater with 1500 Watt element that draws 12.5 amps.
3) Combined load is 18.5 Amps and 2220 Watts, approximately
So you do not want dishwasher and water heater turned on at same time.
Makes good sense.
Solutions:
> Easiest thing would be to put water heater on ordinary wall switch located inside sink cabinet.
Back when garbage disposals first came out, garbage disposal switch was inside sink cabinet. You opened cabine door and flipped the switch.
> Next solution would be to put water heater on a timer located under the sink. There are different timers. In-wall timers and box-type
In-wall timer would need relay/contactor
A battery operated timer like the ST01C would not need to be reset after power outage
http://waterheatertimer.org/Programmable.htmlHere are instruction pages for selecting and installing the relay/contactor.
http://waterheatertimer.org/H230A.htmlhttp://waterheatertimer.org/Install.htmlAdd a comment any time.
Box-type timer like T101 120Volt timer. This timer needs no relay/contactor.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101Timer needs to be reset after power outage, but operates on ordinary 120V power, and is simple to install.
> There is no easy way to wire the dishwasher and water heater together so one is certain not to operate when other is turned on. There are likely electronic control panels for that project. But since you know the hours when dishwasher is likely to be ON, then set water heater timer to turn OFF during those hours. Water inside tank will stay hot for a couple hours, so there is no loss.
It sounds like you are a solid electrician.
If needed, add comment any time for more assistance.
I have a honeywell hz519 baseboard heater and have no operating manual. How do I use the timer? Thanks for your help!
DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator.
I have no manual and don't know how to set the timer.
