MITSUBISHI CRT TV MODEL CT-33AC2SL
TV DISPLAYS NO PICTURE, NO SOUND. HOWEVER THE SET DOES FIRE UP. POWER SUPPLY APPEARS TO BE RUNNING BUT SCREEN IS BLANK. THE ON TIMER LIGHT IS SHOWING RED AS IN THE ACTIVE POSITION. I HAVE TRIED POWERING DOWN FOR SEVERAL DAYS AND STILL NOTHING UPON TURN ON. THE PROBLEM STARTED A MONTH OR SO AGO BUT POWERING THE SET DOWN APPEARED TO FIX IT EVERY TIME. THE RED ON-TIMER LIGHT WOULD THEN APPEAR AS GREEN AND TV WOULD FUNCTION NORMALLY AFTER A SHORT POWER DOWN. THIS TIME I HAD BEEN ON HOLIDAY WITH SET OFF AT MAINS AND UPON RETURN, THE SET TURNS ON (HEAR IT)BUT RED ON TIMER LIGHT IS DISPLAYED UNTIL AV IS PRESSED 3 TIMES, ie AV1,AV2,AV3 THEN NORMAL TV ETC. THIS IS ONLY TIMER LIGHT GOES OUT. I HOPE I HAVE DESCRIBED THE PROBLEM AS MUCH AS YOU NEED. aNY HELP YOU COULD PROVIDE WOULD BE GREATLY APPRECIATED.THANKS!
  • furious87 Apr 18, 2008
    cant find the picture bulb
Check for dry joints in power supply
Posted on May 09, 2008
2 Suggested Answers
  • 418 Answers
SOURCE: how do i change from av1 to av2 . . .av3 ? have remote . .
I think you can do channel down, or up, 'til you go below channel 2, or above channel 125. Then it toggles through external inputs.
Posted on Apr 18, 2010
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Picture on TV ''squeezed'' to center of screen horizontally
Check the horizontal trafo output voltage,the capacitors and the power supply voltage (135-155V dif.the tube diameter).
Aug 14, 2009 | Panasonic Televison & Video
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
No picture or sound
If the screen displays VIDEO 1 then the set is in video 1 mode, looking for a signal on the video 1 input jacks. Press the TV/VIDEO button on the remote (or the set itself if it has it) and cycle around to the input you are actually using.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Panasonic CT-27SC14
The high voltage should be around 29.5 KV and not fuctuate between 20-30 KV that would indicate a high voltage regulation issue then. Are the filaments lighted up in the neck of the CRT? If so then yes you are probably looking at a low voltage issue such as a 12 volt source or a a/v switching IC issue.
Apr 23, 2007 | Panasonic CT-27SC14 27" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
CT-36D12
Instead of explaining the SAP/Stereo function to you, the easiest way to get the TV back to normal is while the set is on press the ACTION and POWER buttons at the same time and hold them until the CHK screen appears. Once that does release the buttons and then press the action button again to exit the CHK screen. Your TV is now back to the factory settings and will need to have the channels programmed again. By the way the SAP/STEREO button on the remote should be near the upper left hand corner of the remote itself.
Mar 25, 2007 | Panasonic CT-36D32 36" TV
Mitsubishi CS-27405 no picture but sound
your problem is the PIP board,tough to repair,can be taken out and replaced with two 10 mfd caps 50v bipolar from pin5 to 11 and from pin 7 to 9
Sep 27, 2006 | Mitsubishi CS-27405 TV
Televison & Video Logo
838 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
