Question about Pioneer VSX-D506S Receiver
Vsx-d506s problem even though standbye light is on and power is connected when i try to turn on reciever a "poweroff" lights up all my other equipment is connected to reciever and powered up but the reciever just lights up poweroff then shuts down to stand bye mode
  • 93 Answers
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Posted on Oct 11, 2007
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
My Pioneer A/V Receiver Model VSX-D506S was purchased in 1997 and has given me years of listening pleasure. Until lately when power-on button is pressed, the display indicates "Power Off" then...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
May 28, 2011 | Pioneer VSX-D506S Receiver
After turning on my reciever i get a flashing poweroff on the display. unit then shuts down
check your speaker connection. if that doesn't work check your fuse to make sure it's good.
Mar 03, 2011 | Pioneer VSX-D510 Receiver
VSX-D457 Display's power off and then shutdown
Most likely it needs one of the output ICs. But check for cold solder rings on the ground connections of the input board. Est. for it to be repaired $100-$120
Dec 17, 2009 | Pioneer VSX-D457 Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
Shuts down after 30 seconds
Maybe the audio amplifier IC are burned
Jun 29, 2009 | Pioneer VSX-D307 Receiver
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
May 26, 2008 | Pioneer VSX-D308 Receiver
643 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
