Question about Nikon D90 Digital Camera with 18-105mm lens
How to slide lock to write position - Nikon D90 Digital Camera with 18-105mm lens
    Novelist:
    Scholar:
  • Nikon Expert
  • 197 Answers
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures
Posted on Jul 14, 2014
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
Jul 11, 2014 | Casio G-zone Commando
Memory card locked slide lock write position
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 07, 2014 | Nikon D60 Digital Camera
Camera saying memory card locked slide lock write psition
The Nikon N75 is a film camera. It doesn't use a memory card at all.
If you're referring to some other digital camera that does use an SD/SDHC card, look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2013 | Nikon Photography
On my extended cab, the front passenger seat will not slide all the way back to the lock position
There's probably something in the way. Get under and behind the seat with a flashlight and check the back end of the rails to see if something is there.
Jul 09, 2017 | 1993 GMC Sierra
Memery card is locked slide lock to write position
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Dec 24, 2010 | Nikon D60 Digital Camera
How do I get the camera off of the Card Locked mode so I can take and delete pictures?
It's not the camera, it's the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 29, 2010 | Insignia Cameras
Nikon d40 memory card is locked. slide lock to write position. pl give me solution quickly my no:8012314307
First take out the SD Memory card. If the tiny switch on the card (Top right) is in Lock position (marked on the card), slide it up to unlock position.
Aug 30, 2010 | Cameras
Card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the slide is already in the correct position, slide it fully the other way and then back.
If that doesn't do it, try another memory card.
Feb 08, 2010 | Casio QV-R40 Digital Camera
On vacation, removed the photo card and it now says LOCKED. HELP
Hi!
If you are using an SD or MMC card, check if the lock button (on the side of the card - a tiny plastic that you can slide) is on the LOCK position. Slide it to UNLOCK position. If it's already in UNLOCK position, slide it to LOCK , then UNLOCK position.
Good luck and have a nice day!
Dec 02, 2008 | Casio Exilim EX-Z750 Digital Camera
The memory card is locked
Sep 30, 2008 | Pentax Optio 33L Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
37 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
