Question about Toshiba Computers & Internet
Warning cooling system is not working on my laptop
  • 33 Answers
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Posted on Feb 22, 2015
3 Suggested Answers
  • 95 Answers
SOURCE: System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Posted on Jun 09, 2008
VonZeppelen
  • 60 Answers
SOURCE: Toshiba Satelite M10 cooling system not working
If you DO NOT hear the fan running, have it looked at by a professional. Your fan may have died. If you can hear the fan running, blow out the fan exhaust port in the opposite direction of normal air flow. Especially on lap tops, the heat sink cooling fins become completely clogged with dust. When this happens the processor overheats causing it to run slow and eventually shuts itself down to keep from going super nova. You should blow it out at least once or twice a year. Also, if you use your laptop on the couch or in bed, place it on a hard surface like a cutting board or something similar that will allow air to flow underneath the computer. This will also help prevent dust from the cushions or blankets and such from clogging the cooling fins on the heat sink faster than usual. Remember blow it out in the opposite direction of normal air flow. You want to blow the dust out the same passage it came in through.
Posted on Feb 21, 2009
Cooling system
If you can buy the pressurized air and blow through the vents of remove keyboard to expose cooling fan a blow with air to remove dust particles
Jan 20, 2014 | Toshiba Computers & Internet
Power ic not working
most of the time,it;s the fan that is not working properly or is getting faulty,change the cooling fan asap....
Sep 28, 2013 | Toshiba Computers & Internet
Toshiba laptop l645 cooling system problem
  • You can try a can of liquiod air first and blow out the dust inside the fan and you can also add more cooling thermal paste to the heat sink above the CPU.
  • There is an youtube video that will show you this procedure if you are technical savy.
Jan 08, 2013 | Toshiba Satellite L645DS4037 Notebook PC
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
Warning your cooling system needs service shut down imediatly
That is rather over the top for an overheat problem. Maybe the heat transfer system has leaked and no longer works properly.
Cleaning the exhaust fan usually clears this error.
Feb 15, 2011 | Toshiba Satellite L500 Series Notebook
Warning comes "cooling system face
Hi. Thanks for your question.
  • Well it seems that you have a cooling problem. It could be caused by many things.This warning may be displayed when system reaches dangerous for components temperature. You can do few things to prevent this from happening.
  1. Make sure laptop is always used on flat surface with it's vent holes not being blocked. People often use their laptops in beds or carpets which causes them to overheat.
  2. Make sure that any vent holes are clear of dust and dirt. If needed use small brush to remove dust. For best results brush + compressed air combination should be used.
  3. If all this isn't case you need to make sure that you can hear fan spinning. This could be a hardware failure and running your laptop like this could lead to permanent damage. ( if your fan isn't running please see this video to get an idea of where it is and how can it be replaced)
utube.png You-Tube video "i3T6om0UA-w" placeholder (do not delete) utube.png
Please do not hesitate to ask more questions if this is needed. Thank you for using FixYa
Dec 13, 2010 | Toshiba Satellite Laptop Cooler
Overheats easily
games make system hot coz they use mor memory ,power and processer units so use cool pad for cooling lap
Jun 25, 2010 | Gateway MX6445 Notebook
A problem with the cooling system is detected. Satellite A25-S207
The sensor that reports the cpu temperature could be faulty or could be fan loose from cpu or faulty motherboard .
Aug 02, 2009 | Toshiba Satellite A25-S207 Notebook
How to fix my Toshiba laptop in cooling system please ?
you probably need to clean the cooling fan...it collects dust over time, and doesn't move the warm air out as it should...its fairly accessible by removing the bottom case cover...please rate my response.....
Jan 29, 2009 | Toshiba Satellite 1715XCDS Cooling Fan...
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Computers & Internet Logo
212 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
