Question about Malber WD1000 Front Load Washer/Dryer
Solve problem to use malber washing machine &dryer
I lost the manual of use for my machine malber washing&dryer ,if it possible send to me by email how to use in english language ,we thank you for your cooporatrion. regards , moustafa
    Problem Solver:
  • 13 Answers
Contact Malber USA (info@malberusa.com) and they can sell you a new manual.
Posted on Jan 07, 2008
Need manual
Unfortunately, this manual is not available online. I emailed Malber regarding the manual. Although they do not have an online version, they indicated that they would mail a hard copy of the manual to your home. Call 800-387-2011 Malber will be glad to send you the manual.
Feb 08, 2011 | Malber WD2000 Front Load Washer / Dryer
I lost manual . there are a lot water inside. how
To get the water out , bring the machine forward
Take the drain hose out of the waste pipe
Remove any clips holding it to the back of the washer
Lower the hose into a bucket and the water will drain out under gravity
As for the knob it is a replaceable part but you will need to contact Malber
Nov 13, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber 1000 Washer Dryer--Dryer doesn't heat
If this is still a problem, where is the red wire attached. Can you send a photo?
Jan 31, 2009 | Malber WD1000 Front Load Washer/Dryer
MALBER WD 800
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 03, 2008 | Malber WD1000 Front Load Washer/Dryer
Where do i put detergent
Contact Malber USA (info@malberusa.com) to order a new Manual.
Dec 11, 2007 | Malber WD1000 Front Load Washer/Dryer
Clothes are still sopping wet when finished
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Aug 28, 2007 | Malber WD1000 Front Load Washer/Dryer
New Malber wd1000...how do you unlock the dryer..picked up at store
TURN THE MACHINE OFF NOW. If the machine still has the transit brackets fitted (which is what I think your post implies), operating it in a wash cycle is likely to lead to severe damage to the machine and could be quite dangerous too. You can find a copy of the manual here: http://www.absak.com/pdf/manuals/Malber/WDman.pdf Before you use the machine again, suggest you look at page 2, and check that everything that should have been removed actually has been. Turning to the question you actually asked, failure to go into a tumble cycle isn't really the sort of thing that would normally associate with packaging having been left in place. Skimming through the manual, there are hints (see page 14) that you're meant to do some counterintuitive things to make the dryer work on this model - like keeping the "half load" button pressed in. Making sure "Spin Cancel" is out is a bit more obvious, but just as important. A.
Jun 22, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
355 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
