Question about Vacuums
How do I wire the power cord for Electrolux DB51X steam Iron to the internal RED ,Blue and White wires? What wires are neutral and which not
Electrolux Steam Iron DB51X
SOURCE: Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
Posted on Oct 10, 2008
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
Posted on Oct 18, 2008
  • 140 Answers
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Posted on Dec 31, 2008
heatman101
  • 43501 Answers
SOURCE: Shark steam mop heats up but stopped putting out steam.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 04, 2010
  • 250 Answers
SOURCE: I have a stirella dual
It sounds like the steam valve inside the iron is stuck open. You have to take the iron apart and free it up by lightly scraping water deposits off it with a screwdriver.
Posted on Mar 16, 2011
Which wire is the power wire on the jlt pump
post a picture of the wiring but hot is generally black neutral is generally white ground is always green sometimes they use red blue dark yelloow purple as hot so it is hard to say which color the unit uses there are only about 3 wires maybe a 4th if it has a seprate switch for the pump but the picture of the circut would answer my questions
Jul 12, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Can't hook up power cord to main motor on Hoover model F5915100
You have a black and white and green wire. Green is ground white is neutral, black is hot . Should say on the motor either L1 = black wire. L2 = white wire , G = Green wire or it say H = black wire, N = white wire , G or the symbol for ground = green wire
Apr 11, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I need to know how to hook the wires up to the start switch. There are two wires from the external cord and two wires from the internal cord.
white wire to neutral black wire to hot if you post colors I could help you red ,orange, black,pink, blue, or violet are usually hot guessing a striped wire is usually neutral please post colors
Apr 14, 2013 | Dyson DC14 All floors Bagless Upright...
Following old directions found online I opened an Electrolux Ambassador III to fix the cord winder. When reassembling, I found a loose white wire. Where should it be reconnected?
A white wire is part of the power wiring (neutral), but if the machine runs ok, it may be a left-over from previous work or original manufacturing. If the machine does not run now, then look obvious bare connectors to reinstall it. Hope this helps!
Oct 02, 2010 | Electrolux Vacuums
GE on/off timer for a bathroom fan - switch has four wires Green - ground White - neutral Black - power Blue - lead My fan has two - white neutral and black lead I have tried...
I would guess that the black wire on the timer is the power in and blue is the power out to the fan (hook it to the black wire going to the fan) The other colors are right.
Mar 23, 2010 | Vacuums
Electrolux Epic 2500 suction stopped
It could be the switch or could be the suction motor. Also, there is a thermostat on the motor that will shut it off if you don't have the air flowing to keep it cool. If that is the case, the motor will re-start after it cools down.
If the motor dosen't start, the cheepest way to start is to buy a new switch and install yourself. Just make sure where the wires go. The single terminal is to the front and the two terminals to the rear. The black wire goes to the front single terminal, the red wire goes to the far back terminal and the blue wire goes to the front back terminal. The suction motor should come on first and then the power nozzel. If not in that sequence,reverse the blue and red wires.
If that fails, take it to the Aerus/Electrolux shop.
Sep 01, 2009 | Electrolux Vacuums
My Model G electrolux works great until one day it
Use a multi meter and use checking continuity, from one side of the switch to the other. If you have continuity, the switch is good. It is also likely that the power cord could be bad, again checking continuity put one probe on one prong of the plug, and the other probe on the black, white, or green wire (thus checking the continuity through the cord)
It is common that cords get pulled out of the wall socket incorrectly, or accidentally when you run out of cord as you word away from the power source, stretching and eventually breaking one of the wires inside the power cord.
Jan 19, 2009 | Electrolux Vacuums
Dec 30, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
