Question about Dell Inspiron 1545 Notebook
PC turns on but will not boot up; unable to run directly from cd rom
Powers on; black screen; in safe mode unable to run cd rom from command prompt; would like to reformat and do clean install
    Top Expert:
  • Dell Master
  • 25,241 Answers
Just before it boots, press the button, (F1. F2, Esc etc) to gain bios screen. Set the boot drive to DVD ROM. Insert your boot disc and re boot.
Posted on Nov 21, 2013
4 Suggested Answers
  • 998 Answers
SOURCE: Will not boot to Safe Mode
Try to boot from the Resource CD by selecting the <F12> key and select boot from CD/DVD drive. If you tried to run the "Diagnostics" option from the <F12> boot menu and it went to command prompt, there might be an issue with your hard drive or the "Diagnostics" partition is corrupted or missing. If all tests pass using the Resource CD, then your OS is probably hosed. As for the 9 LED light, that just indicates that your numeric keypad is enabled.
Posted on Oct 17, 2008
TimmayG
  • 86 Answers
SOURCE: startup repair won't repair
It sounds like your leaving your Installation Disk in the drive. Take that out and run safe mode, then just plug in your flash drive as normal and it should detect it and you can copy your files to it. If not, use s CD and burn the files you need on them then you can proceed with Wiping the drive. If this fails, Install XP but there is a option to not have the drive formatted thus this keeps all files in tact. Reinstall XP like this, take the files you need and then reformat and reinstall XP and you should be fine. After doing all this, run a virus scan and have it run regularly because it may have been a virus that caused the problem to begin with.
Hope This Helps
Posted on Nov 21, 2008
SOURCE: Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Posted on Mar 16, 2009
White screen virus
Sounds like no GPU. With the hard drive, RAM and battery removed, plug the power in and press power, It should load to bios. If it doesn't, there is a GPU issue. If it does, you will soon know what the issue is.
Nov 21, 2013 | Dell Inspiron 1545 Notebook
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 08, 2012 | Computers & Internet
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Jul 16, 2011 | Dell Latitude D810 PC Notebook
Troubleshoot D530 Pentium 4, i get the boot screen, over n over
Run hard drive tests, if HD tests good, and no data to keep, restore os from restore partition with f10. If data needs kept, run a repair installation of os. Run fixboot and fixmbr commands from prompt. Also try sfc/scannow from command prompt.
Nov 21, 2009 | HP Compaq d530 CMT Intel Desktop PC -...
HP Desktop PC, won't boot even under safe mode
if the system was able to enter the desktop and restarts...once possible cause is a virus...scan the pc via safemode or reinstall windows.
but if it didn't enter the OS desktop...cause might be the boot loader or MBR is damage..
worth a try:
Run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. At the command prompt, type this commands one at a time.
FIXMBR C:
FIXBOOT C:
COPY [CDDRIVE]:\I386\NTLDR C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM C:\
BOOTCFG /rebuild
6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Feb 17, 2009 | Compaq (261671-001) Motherboard
Computer problem
that is your DOS prompt
Try typing at the black cursor (chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
If that does not work
Shut down PC
F8 on boot get back to Advanced boot option
SAFE MODE WITH NETWORKING
Sign in as ADMIN or Owner
say yes to get to Desktop
Once you get to the Desktop
(Windows XP)
Start>RUN>CMD (This will be the command prompt window}
(chkdsk /r <ENTER> <Y> <ENTER> Restart the PC)
(Vista)
Start>Start Search>cmd>(above) Right click on CMD>Left click(RUN ADMIN) (This will be the command prompt window)(chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
Jan 23, 2009 | Intel D845GVSR Motherboard
Windows not starting successfully.
You must remove all usb devices and any hadware you have recently installed if this problem still occures you will need to reinstall windows xp
Jan 11, 2009 | Computers & Internet
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Sony vaio not loading windos
Try booting XP with the installation CD & use the recovery console to boot the laptop.
From the Setup CD-ROM
Insert the Setup compact disc (CD) and restart the computer. If prompted, select any options required to boot from the CD.
When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the Recovery Console. When prompted, type the Administrator password. At the system prompt, type Recovery Console commands; type help for a list of commands, or help commandname for help on a specific command.
To exit the Recovery Console and restart the computer, type exit.
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Unable to boot up after windows xp
If you can get into the BIOS, try setting with default settings.
Dec 19, 2007 | MSI K8MM-V Motherboard
Dell Inspiron 1545 Notebook Logo
Alun Cox
