Question about Texas Instruments TI-83 Plus Calculator
Ti-83 error message invalid dim - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat
plot features. You can correct this by turning off the stat plot
features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Jun 08, 2014
  • 7993 Answers
SOURCE: ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Jan 16, 2010
  • 7993 Answers
SOURCE: i have a problem with my ti 83. i am traying to
Posted on Feb 19, 2010
  • 7993 Answers
SOURCE: Clearing or correcting an error message on the TI-83 Plus
Press [STAT] to open the Statistics editor. From the menu that displays, select PlotsOFF and press [ENTER] twice. The calculator answers "Done".
Open the [Y=] editor to enter the functions to be drawn. Use the Trace ONLY after the graph has been displayed.
To clear any message without necessarily removing the conditions that yield the error press the CLEAR button.
Posted on Apr 13, 2010
  • 102366 Answers
SOURCE: ti 83 error message invalid
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If that's not it, please reply to this post stating just what you did to generate this error message.
Posted on Oct 01, 2010
  • 35 Answers
SOURCE: TI-83 Plus Err: INVALID DIM
The calculator is trying to graph points in a list and they are either empty or not the same length.
If you do not want to graph points in a list, go to 2nd, Y= and turn each of the three plots off.
If you are trying to graph points in a list, check that you entered them correctly, they are not the same length, and then check that in the StatPlot menu you are asking the calculator to graph the correct lists.
Posted on Mar 06, 2011
Invalid dim?
The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat
plots. To turn the stat plots off, press {2nd}[stat plot], and then select 4:Plots Off.
Jan 23, 2011 | Texas Instruments TI-83 Plus Calculator
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
Ti 83 error message invalid dim
Oct 01, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: My TI-83 reads "INVALID DIM" when I try to graph a...
May 17, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Apr 13, 2010 | Texas Instruments TI-83 Plus Calculator
How do I clear ERR: INVALID DIM
Reset memory to default, the error will disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps
Sep 10, 2009 | Texas Instruments TI-83 Plus Calculator
Error invalid dim
Hope it helps
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
Error message
I got the solution from someone else. Here it is:
http://www.lcc.edu/mathsci/calchelp/topic6.htm try this website. Scroll down to step number 5. Works great :-)
Aug 30, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
