Question about Siemens WT79020EU Electric Dryer
Siemens dryer iq300 instructions - Siemens WT79020EU Electric Dryer
The start/stop light on my Siemens tumble dryer iq300 is flashing and the door light is lit. The dryer won't start,but the door is properly closed and nothing is obstructing it. Any suggestions pleas
Hey GOD IS GOOD !!!!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Sep 28, 2014 | Dryers
Washing machine error codes
Contact manufacturer or service agent
Aug 11, 2014 | Siemens iQ300 SN26M653GB Full-size...
Our siemens WD12D520GB [iq300 washer dryer] often stops drying after 7 minutes. running a diagnostic test [6 o clock, hold spin rpm, clockwise 1 notch, release spin rpm button] gave f08. repeating the...
This info should be on the insert hidden somewhere in the machine..look behind the lower kick panel..under the lid...on back...somewhere for the folded paper insert.
Theses are Error coder specific for this manufacturer.
Oct 16, 2013 | Siemens WTXD8300 Electric Dryer
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
Hi, we have a Siemens IQ300 Condenser Tumble Dryer which we have recently inherited. Unfortunately it worked for a wek before just stopping. The lights are on and everything looks normal but when you
Check to see if it is properly grounded and that the incoming voltage is correct (120V or 240V) for the wiring config you have.on the dryer as it sits. Also try unplugging and wait a minute or so before plugging back in. This will sometimes reset dryer electrical components to factory settings.
Dec 07, 2012 | Dryers
How to open the door of the siemens iQ300 washing machine
This problem has nothing to do with water in the machine. My IQ300 regularly refuses to open on the drying cycle! You have to open the small round compartment beneath the door and pull down on the black plastic strap to the right - you may need a utensil to pry it out. What a rubbish machine.
May 29, 2011 | Siemens WIQ1633 Front Load Washer
Siemens WT79020EU Electric Dryer Logo
219 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
