Question about LG 20LS7DC 20 in. LCD TV
Lg remote will not change channels - LG 20LS7DC 20 in. LCD TV
Lg tv volume and mute control
It is possible that you need to program your remote control for your LG TV. Take a look at this link, it has all the info in it: www.verizon.com/support/residential/tv/fiostv/remote+controls/setup/setup.htm
Oct 02, 2017 | LG Televison & Video
My lg tv is stuck on chnnel 7. I can't change the channels.
try changing the channels from the tv buttons and not the remote control and if that works your tv has a faulty infra red remote sensor which is easy to replace if you can use a screwdriver
Sep 29, 2014 | LG 32LG30 32 in. LCD HDTV
I have to go 2 inches to my LG televisionwith my
1. replace battery in the remote control
2. check if the remote works. Take any video camera (cell phone camera) and see trough it if the remote transmitter blinks when you press buttons.
3. if you use a cable/satellite remote control to change channels you should point it to a cable/satelite receiver not to a tv
Oct 14, 2013 | Bose V25 Theater System
My at&t remote will not change the channels when the room gets dark
if its an ATT remote the channel changing is a function of the cable box--you may wont to reboot the cable box if the channels still dont change i would contact or cable provider
Oct 14, 2012 | LG 42LC2D 42 in. LCD HDTV
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Jul 28, 2008 | LG 42LC7D-UB Television
Channel keeps changing
If you are using the remote to change channels it sounds like either the front of the remote and/or the receiving “eye” on the TV need to be cleaned, OR (more likely) the button on the remote is sticking. It is actually a button that pushes on a membrane under the entire remote panel. This is generally caused by some sticky liquid (like Coke) getting spilled on it. If you are brave enough, you can take the remote apart and clean it with denatured alcohol. Otherwise you need to replace your remote. If possible borrow a universal remote and see if it still happens. If that doesn’t fix it you have a bad IR receiver and/or a serious internal problem.
Jan 29, 2008 | LG 32LX1D 32 in. LCD Television
LG 20LS7DC 20 in. LCD TV Logo
20 people viewed this question
Computer Repairing
Computer Repairing
