Question about HP Pavilion 513n (P9850A#ABA) PC Desktop
Motherboard i bought an internal hard drive, its 360GB and so forth. I went to install it on this computer and cannot find a SATA port on the motherboard. Do I need to use an add in SATA card, and if so what kind should I get and where can I find it?
  • Anonymous Mar 18, 2014
    What are the correct SATA ports on the 6803 motherboard are for the 6GB/sec drives?
  • Anonymous Mar 19, 2014
    I connected the Sata Data cable to motherboard, but the drive won't turn on when I turn on the computer.
    Novelist:
    Scholar:
  • 167 Answers
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Posted on Oct 09, 2007
  • Deepu Amalan
    Deepu Amalan Oct 09, 2007
    An advanced SATA -II adapter is in the image (150 Mbps)
Dell Optiplex 755 - 2 sata ports (2&3) not working on motherboard. They have been switched to "on" in the bios, but will not recognize sata HDD or sata DVD. Only ports 1 & 2 are working, so I now have a...
hi There.
this is all i could find out from the internet so not sure if this will help you out.
(I went into BIOs again after I looked the SATA port over on the motherboard. The SATA ports on the motherboard are listed as 0,1,4,&5. In BIOS the SATA ports are 0.1.2.3.4. & 5. I have been trying to turn on 2 or 3 as they are the next ports and never tried 4 or 5.
When I turned on 4 and 5 everything is working fine.
Why do they list SATA ports 2 and 3 when they are not present on the motherboard)
or see if this link helps you.
Dell Optiplex 755 2 sata ports 2 3 not working on motherboard Google Search
Dec 15, 2017 | Computers & Internet
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
How 2 install a triple format sata internal drive in a gateway desk top
check for a open sata port on your computer. if there is one connect the hard drive with a SATA cable to the sata port on the motherboard.
connect the sata power to the hard drive or a molex to the hard drive if you do not have one. do not connect sata and molex to the hard drive together. if you don't have a molex connect you will need a molex to sata power adapter.
after connecting the hard drive to your pc. turn it on. in windows xp it will auto detect the hard drive and may prompt you to format the hard drive.
Mar 28, 2011 | Computers & Internet
I want to make my WD1600AAJS hard drive a master hard drive, but the port is diffrent than my other hard drives. what do i do?
A SATA drive cannot be set to master or slave like a PATA drive can. SATA only allows one device per port. If the problem is that you don't have any SATA ports in your computer, you can get a SATA host adapter card for your system, update your motherboard to a motherboard with SATA ports, or get a PATA hard drive.
Feb 23, 2011 | Western Digital WD Caviar Blue WD1600AAJS...
Can i replace the hard drive parellel type of inspiron 2200 into SATA type hard drive?
Ofcourse you can replace the hard drive as Inspiron 2200 are usually supplied with SATA hard drives. But call Dell support team as they will only replace the hard drive if your computer has hardware warranty or else they will ask to purchase it.
Chio,
Anirban Mazumdar
Dec 04, 2010 | Computers & Internet
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
Bought internal harddrive and don't know where 7-pin SATA port is on motherboard, or Sata power connector is from PC.
hi, sorry to tell you this but that model of dell desktop does not have sata ports or sata power connectors and has no spare drive bays to mount the hard drive either , you would be best to try and return the drive and purchase an external hard drive and connect it to your PC via the usb socket .
Hope this helps
Apr 24, 2010 | Dell Dimension B110 PC Desktop
How to install secind sata hard drive
It all depends on how many SATA ports are available on your motherboard.
Older motherboards (EIDE+SATA) usually only had one SATA port. In that case I'd advise purchasing an internal PCI SATA card (around US$ 30).
Modern motherboards (SATA + legacy EIDE) have two, four or even six SATA ports available, and you basically just have to screw the hard disk in an empty slot of the appropriate size (3.5"), and connect the cables. You may have to purchase both data and power SATA cables though. Then, format and install the drive (advice: use the one OS you use more often) from Control Panel > Administrative Tools > My Computer > Disk Management. And you're done.
Feb 22, 2010 | Computers & Internet
Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to...
you will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Aug 11, 2008 | Computers & Internet
HP Pavilion 513n (P9850A#ABA) PC Desktop Logo
210 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
