Question about Vizio Gallevia GV42LF 42 in. LCD Television
LCD TV - Vertical Blue line
Phillips 26" LCD TV Vertical Blue line covering length of screen (right down the middle) Thought it could be a stuck line and tried to "wash it" Any ideas??
  • 4 more comments
  • Anonymous Nov 12, 2007
    sony bravia 40"
    I have a red line continuous from top to bottom right in the middle of the screen.
  • Anonymous Feb 25, 2008
    My Zenith P42W46X is less than 4 years old and there is a vertical blue line that has developed right across the screen. Can it be repaired? is it worth being repaired? Someone please email me! [email protected]
    thanks
  • andrew986 Nov 29, 2008
    Mine is a 37-inch Vizio LCD, same problem. Vertical blue line about 40% of the way from the left side of the screen, goes about halfway up the screen from the bottom.
  • g_kettlewell Mar 07, 2009
    I have a Olevia 40 inch LCD and it is approx. 18 months old and about 2 months ago I get a vertical blue line approx, 1/3 from the left side from the top to the bottom, It shows up as bright blue line when the picture is dark or the background is dark, and when the picture is bright or a very light background it appears yellow or gold colored and fainter. If you tap the top of the screen directly above the line it goes away, however it will reappear later. When the tv, is first turned on it run perfect for about 45 minutes to an hour.
    Please email with any solutions. [email protected]
  • Adil Asif Jul 23, 2013
    Guest Dell 22" LCD I have a red line continuous from top to bottom right in the middle of the screen.
  • Anonymous Mar 15, 2014
    vertical blue line on tv
Use menu and h/v then change then move to higher level and it will take it away.
Posted on Aug 24, 2008
  • 65 Answers
What about voltage? Maybe could adjust Vs down about 5% or so and see if that helps. Only do that when line appears. Probably not that though.
Posted on Apr 03, 2009
  • Anonymous Jul 11, 2009
    When I first posted to this solution I was a little inexperienced with the TV's fixes. If you have a solid line running from top to bottom on your LCD TV then it is your panel going out about 99% of the time. If you only have one little line mark that spot on the TV where it is located and then you could take a big chance and try and fix it. It is rare but there is a slim chance it can be fixed by tearing the entire TV apart down to the screen itself where you can see the back of the panel and the wires going into it. Then if there is anyway to power the TV up where you can see the line chances are it is a short in the wire that connects to the back of the panel...or if you are lucky it is a cold solder joint on the backside of the TV where the wires that come out of the control board. But basically it is nearly impossible to fix and if you can stand to watch it you would be better off.
    Thanks,
    Ced
  • Mike Aug 31, 2011
    you could try taking the tv apart then power it up and tap the line top to bottom with something like the handle of a screw driver as it could be a stuck pixel
SOURCE:
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
Screen not working lines,color change,olny on blue screen with line down the middle
Let's see if I understand the problem: when you have a blue screen, you see at least one black vertical line in the center, and when you have other material on the screen the same line(s) is yellow (or conversely, you have a blue vertical line that stays on all the time). If I have parsed your complaint correctly, then you have a bad connection in the LCD panel or a bad LCD column driver chip. It is possible that an expert technician can solve a connection problem by "massaging" the connection or taking it apart and reassembling it, but sometimes this only creates more problems.
Replacing a failed LCD panel driver chip requires specialized equipment. Search for "LCD TAB repair" to find a company with the right tools.
Oct 23, 2010 | RCA L22HD31 22 in. LCD HDTV
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Polaroid FLM 2632 HDTV
I hae replaced my polaroid FLM-2632 3 times it is a crappy tv same problem every time do not buy one
Dec 18, 2007 | Polaroid 3211TLXB 32 in. LCD Television
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Vizio Gallevia GV42LF 42 in. LCD Television Logo
11,189 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
