-   My Nokia 5200 fell on the floor and stoped ringing, It only vibrates. The musical player and ringing tone doest not play. But when i connect my ear phone it plays through the ear piece.-   loveadanow
Dec 24, 2008
-   will vibrate but will not ring
-   rod0305
Oct 29, 2008
-   Does not ring but will vibrate. It has to be a software issue because it will play music and other sounds from text messages.
-   jhendricks
Oct 08, 2008
-   Phone will not ring however phone will vibrate Profile changed to general theme changed volume maxed out phone reset to manufacturers default battery charged taken out and replaced phone is still serviceable can send, call and receive. Have checked phone on incoming calls and text on screen says silent i have not been able to clear this by any of the methods above. -   pdlukose05
May 19, 2008
-   Phone doesn't ring, only vibrates whether the phone vibrate is on or off is still vibrates. Ringtones doesn't work nor play.-   Guest
well such type of problem eventhough the ringer (hardware part) is replaced still ringing problem persists according to my suggestion there are some resisters in the main board that are damaged or totally wearout so try to see them and replace them carefully (u need to solder them ) try this am quite sure solve ur problem .
I found I was missing calls. It was because the ringer wasn't working. Vibration works ok. I've tried replacing the ringer program with other programs. Doesn't work. Product is now essentially useless for people calling me although I can call them. All other functions work, even other sound functions, with the sole exception of the ringer.
Comment by Guest, posted on Mar 24, 2008
phone will not ring, i have set ringer to loudest. its not on speaker. it only vibrates. please help
Can have a conversation and answer phone from visual clues, but phone will neither ring nor vibrate any more even though provile is normal and all settings indicate that ringing should occur. Suspect a physical problem with phone.
