Question about Onkyo DV-CP500 Multi-disc DVD Player
Dvd player stuck in standby mode - Onkyo DV-CP500 Multi-disc DVD Player
3 Suggested Answers
  • 56 Answers
SOURCE: DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
  • 56 Answers
SOURCE: Re: Onkyo DV-CP500 DVD player stuck in standby mode (by 7 users)
Hi Yes, sorry just saw this comment. Swap out C7, C17 and C18 in the power supply. Also I would check if you are getting 9Volts to the motor control IC's pin 7 coming off of C005 on the Mechanism Board which is under the unit. The hole for the C005 cap was drilled into a very narrow section of the circuit board and has marginal connection at best.. mine stopped working because of this 6 months after I fixed the power supply.
Posted on Apr 12, 2009
How to power on bypass standby mode
Hold in power button for few seconds
Sep 02, 2014 | Televison & Video
Stuck on standby mode I have unpluged and it still is stuck on standby
It sounds like power supply problem, I have found that sometimes the main filter capacitor opens causing the machine to fail. It will take a professional to determine if that is the case or there is something else wrong.
Dec 28, 2010 | Memorex MVD2042 DVD Player
Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Nov 28, 2008 | Onkyo DV-SP301 DVD Player
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
Kawasaki pvs 1965s
unplug it for 30 seconds, then plug it back in.
Hope this helps
Dec 29, 2007 | kawasaki PVS1965 Portable DVD Player
Stuck on standby
if you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at josocuervo@yahoo.com
Nov 09, 2007 | Memorex MVD2042 DVD Player
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Onkyo DV-CP500 Multi-disc DVD Player Logo
18 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
