Question about Ricoh Aficio 2015 Copier
Ricoh 2015 printer
It is showing B follow instructions in right cover to remove
  • ravi v v Oct 09, 2007
    Dear Sir,
    My printer Ricoh Aficio 2015 is showing the error " B follow instructions in right coveer to remove"
    I replaced new toner then also I am getting this error
    please give me the solution for this error.
    thanks and regards
    Ravi V V
    Jr. Network Administrator
    Navayuga Bangalore India.
The B is saying there is a jam in the right hand side of the machine. You may have fuser stripper fingers popped out of place causing it to jam or you may have a torn off piece of paper stuck between the registration rollers. Try spinning the black and silver rollers by hand and see if any paper comes out.
Posted on Oct 09, 2007
SOURCE:
How do I solve a problem with my Printer Ricoh Afacio 1515MF, it says check the instructions in the right cover yet there's no paper jam.
Usually theres a dirty sensor. Remove the drum and toner hopper then give it a blow with a blower. If you know how to remove the fusing unit, you will find two sensors on it, clean them. Otherwise it's the paper feed clutch.
Dec 17, 2014 | Ricoh Aficio 1515 All-In-One Laser Printer
How do I fix a problem with my photocopier Ricoh Aficio 1515MF, whenever I try to copy it tells me to "Follow instructions in Right Cover to Remove"
Sounds like it thinks there is a jam. Check registeration sensor flag also exit sensor and duplex sensor. Could be dust or fuser sensor out of place or the duplex guide is broken
Dec 16, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 750 (495 cODE
Ricoh 2016 show me
follow instrctns in right cover to remove
Nov 19, 2013 | Ricoh Aficio Office Equipment & Supplies
Follow instrctns in right cover to remove
Probably is a paper jam. Make shore that you remove all the peaces of paper.
If you have any more doubt reply to me so i can help you
Mar 31, 2011 | Ricoh Aficio 2015 Copier
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
Describe how to remove a hard drive from Ricoh Afcio 2045
Remove the back cover, It should be located directly on the right of the machine. Just requires a phillips screw driver. REMOVE POWER FIRST .
Jul 26, 2010 | Ricoh Aficio 2015 Copier
is it a miss feed problem? open the cover on the right cover of the machine then remove the jammed paper. then close the covers
May 26, 2010 | Ricoh Aficio 2015 Copier
On lcd massage
some times the nipple (cover) of the toner stays in the toner holder this wont allow the new one to be opened
Sep 22, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh Aficio 2015 Copier Logo
603 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
