Im facing the following proble while I trying to logon at the Designer desktop.
Cannot access the repository.
[repo_proxy 13] SessionFacade::openSessionLogon with user info has failed(CMS host '10.44.250.105' address was resolved properly, but cannot be reached to establish a CMS connection. Verify that your router/firewall allows communication on port 6400
(hr=#0x80042a01)
I use windows VISTA.
Whats happening here is the repository URL is no longer available. This happens from time to time and you usually have to look for a new repository URL. Check the link below for the newest kodi builds and the repos that go with them. There is also some good tutorials on how to install the new builds.
If your having trouble installing the Exodus addon, it is possible that they repository was taken down. To remedy this, you need to find the new repository. To save you some time the new repository URL is kdil.co/repo. This is the new repository for the new Exodus addon, that was just re-launched again in 2018. Anyways I hope this helps.
There is a possibility that you have your cache filled up on kodi. You can clear cache on kodi by following the given steps at the end of this post. Secondly you can setup best kodi builds to continue smooth streaming.
Clear Cache on Kodi:
Open Kodi Jarvis > Then click on System menu in front of your screen > Now select File Manager > Double click Add Source option at the bottom.
Once you click on Add Source, a box will soon appear where you need to click on 'None' option and type http://srp.nu/ > Click Done > Type URL Name below 'Super Repo' > Click Done > Then click OK.
Once you are done, go back to Kodi Main Menu by pressing 'Esc' button on your keyboard > Go to System > Then select Add-ons > Then click on Install from Zip File > Super Repo > Then select Jarvis > Click on Repositories > Superrepo > superrepo.repo.0704.zip
Now select Install from Repository > Then Super Repo Repository [Jarvis][v6] > Go to Add-on Repository > Select SuperRepo All Repository [Jarvis][v6] > Hit Install
Go back two steps and click on Install from Repository > SuperRepo All Repository [Jarvis][v6]> Program Add-ons > Merlin Wizard > Install
Open Merlin Wizard, go to Tool Box option > Here you will presented with 3 options i.e. Clear Caches, Delete Packages, and Delete Thumbnails. The space that each of these options consume are also listed below these options.
Adding the Exodus addon might be a little hard at first but once you do it a few times it gets much easier as its the same process over and over for each addon. To Install Exodus on Kodi please follow the steps listed below.
1. Add A source for the repository. (kdil.co/repo is the source repo)
2. Name the repository and click ok.
3. Click on install from Zip file. Then find the kdil repo file you just a saved.
4. Then click on the install from repository and find then go the video addons.
5. Once in video addons within the kdil repository, find the Exodus addon, then click on it and then click install.
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Things you will need is "Guts" and "Guts" everything.Please follow the below steps and enjoy.
1 . FACE BOOK BY PROXY Everyone knows that school is a giant waste of time, especially in America. But the popular thing nowadays is disallowing students the right to waste their own time getting into all kinds of trouble on the Internet when the teacher thinks everyone's grinding away on schoolwork. That's gotta stop. What you need is a proxy. See the resources section below for the freshest batch of unblocked, unknown proxy addresses that you can use to sneak around your school's face book blocking software.
2 . FINDING AN UNBLOCKED PROXY A proxy is essentially a middleman. You're at school and your school doesn't want you accessing Face book, so what you do is get a proxy to do the dirty work for you and bring you and Face book together in Internet bliss. And the whole time you're using face book, the school just sees that you're on some no name website... the proxy site. But it can be more difficult than you think because your school's blocking software is frequently updated to block all the new proxies and naughty websites popping up every day. The trick is to find the freshest proxy lists, that way you know you're using a proxy that your school has probably not yet blocked.
3 . HOW TO WORK THIS THING? Here's one of the newest proxies to pop up in the last few hours: http://969696.Co.CC When you go to the above URL you find a box that says, "Enter the URL Address:" What you're going to want to do right here is enter in the URL address that your school has blocked. In this case it's Face book we're trying to access, so go ahead and type in "http://www.facebook.com" and hit Enter, or for the purists you can click on the Surf Now! button.
4 . WAIT The bad thing about proxies is they tend to be really slow and difficult. Sometimes they work like a charm. Other times they work like a curse. You have to remember that you're using another computer to access a website and then bring that website back to you. Combine this with a school full of slow networks and clogged computer systems and you end up with quite a bit of waiting time on your hands. But if you're sitting on the Internet at school with enough time on your hands to research how to access Face book at school, it's probably safe to say that you don't really have much else better to do anyway.
5 . JOIN THIS FACE BOOK GROUP Ironically enough, one of the top places to find all the newest proxies relevant to unblocking Face book is actually a Face book group. See the resources section below for a link, but do yourself a favor and join this group from your home computer and check out all the newest proxy information at night before school. That way you'll be the hippest dude in school - the dude who can always get on Face book.
Hope the above information will be helpful to you. Thanks.
There are many factors that denies access to your face book.
1. If it is a corporate office there might be some proxy settings which denies access.
2. Probably cache on your local machine / laptop, in this case try clearing your browser cache and cookies OR try it in http://anonymouse.org Or any other proxy sites.
