Question about Canon PowerShot A95 Digital Camera
Canon a95 i have a canon a 95 suddenly when i switch on the cam i find a black lcd no picture appears on lcd and even when i take picture and put in computer it shows a black screen only no picture pls help
  • Canon Master
  • 4,738 Answers
This definitely sounds like it's a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your cameras warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
SOURCE:
Blank screen
Try this...if you can still get into the setup menu, scroll to "reset" and follow the on-screen instructions. If not, remove the memory card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. Did that help?
Sep 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon ixis camera has suddenly developed 2 black lines thru d screen even wen put off.. wat is it??
Do the lines come on the photographs ..... if no then it is a LCD problem ... the two lines are having trouble getting the data ..... the LCD has to be replaced ......
Oct 26, 2008 | Canon IXUS i7 Digital Camera
LCD color get mixed
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is worldwide, and regardless of your camera's warranty status. Please check the following two links for more info:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Feb 06, 2008 | Canon PowerShot A80 Digital Camera
No picture in rec mode, cam switches off in 10sec
Try using the Dummie Battery and connect that end to charger.
This way you will know that you don't have battery problems.
[email protected]
Dec 24, 2007 | Canon XL1S Mini DV Digital Camcorder
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
No view
Yes , what you seem to have is a camera with a faulty CCD sensor ( see enclosed image ). Good news is that Canon fixes this particular fault free of charge.015f5e1.jpg
Oct 31, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
NO PICTURE ON LCD SCREEN OR VIEWFINDER
model # is required for me to help you.
Sep 09, 2007 | Canon DC10 DVD Camcorder
Most of picture blanked out or blocked out
This seems to be a oricessing orblem and the process is failing to complete or corrupting. Rreformat the card in the camera Try another card.
Jun 04, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
