Question about Electrical Supplies
I hace a 1.3 meg cat generator with v12 engine it will not come out of cold mode help
07 suzuki xl7 po420 code. Oxygen sensor bank 2 sensor 1 i believe. Location in the engine. Thanks..
the cold from hell,,
CAT monitor. know it well, too well.
no its not that.
the code tells that engine has a lazy or dead cat.
no engine stated.
its and XL-7 not and XL7, they are different cars.
3.6L V6
bank one is failing the person who told you bank 2 is full of beans.
"Catalyst Efficiency Below Normal (Bank 1)" SM quote. we change the front B1S1 front sensor first.
then the B1S2, sensor next.
then the CAT if sure no exhaust leaks are on Bank1.
S1 is front
S2 is rear
bank 1, is cylinder 1 side
bank 1 is,, right bank, usa is passenger side
look for leaks first in exhuast
then bad 02s, on right side , damage to wires.
the new sensors.
then new cat, $$$$$$$$$$$$$$$$$$$ last
Mar 12, 2017 | 2007 Suzuki XL-7
What fuses to check when Cat 3306 Generator Set is Not producing 480 vlts
Make sure regulator is applying foeld voltage to the exciter coil. If so flash the field first before checking further. I can help you if you do that first.
Sep 26, 2014 | Electrical Supplies
HOW TO MAKE VALVE SETTING FOR CAT 3412
i don't have answer to my question how to valve lash the Cat engine
3412 Generating set
May 22, 2014 | Caterpillar 3412E DITA Marine Propulsion...
I have a 1996 dodge dakota 2wd took out the 5.2 and put a 5.9 in headers no cats no 02 sencers and my problem is when i start it cold idle is good but if i take it to 2,000rpm it will bog down then...
Without input from the O2's, the engine goes into fail-safe mode and runs in a full rich fuel trim. When the engine is cold the spark plugs are being "loaded up" with unburnt fuel, and engine stumbles. Hope this helps.
Mar 14, 2014 | 1996 Dodge Dakota
Looses power after warm up
Is the check engine light on or are you showing any codes?
There are dozens of possible reasons for this. A common one is the O2 sensors, but this would likely show a code.
There is a lot of "stuff" that happens between cold start and normal temperature running, most of which is tied to sensors and what the feed to the Engine Control Module.
Most (but certainly not all) things that aren't right get detected by the ECM and generate a code that helps further identify the root cause. Even these codes can be a bit misleading. A Toyota code that says one needs to change the catalytic convertor can often be fixed by replacing the before cat, after cat, or both sensors and that is a lot cheaper than changing the cat. (most of the time shops will automatically change these sensors when they do replace a cat, otherwise the new cat doesn't fix the problem).
Oct 26, 2013 | 2001 Honda Civic
2007 Suzuki XL7 O2 sensor Bank1 - sensor1. Where is it located?
in the exhaust pipe after the cat converter of the bank closest to the firewall
Jan 02, 2012 | 2007 Suzuki XL-7
We just relocated our cat gen, we start it up but does not generate voltage and goes instantly to cooldown mode.
Which model CAT???? No voltage check the AVR for exciter output first, it may be a control issue shutting down the AVR, so before replacing check for fault sensor input
Oct 06, 2010 | Caterpillar Electrical Supplies
How can i identify which engine i have.i have just bought a v12 engine
V12 6.0 motor = N73 type
V12 5.0 motor = M73 type
Oct 02, 2010 | 2006 BMW 750Li
I have a 2001 s600 Mercedes Benz v12 i just blow out my kat and replace o2 sensor now my accelerated dont wot it like it not reading it . do i have to rest any thing
The only thing to reset would be the check engine light if it was on but would not cause this,how did you blow cat out, theres no blow cat out,also did you use oe o2 sensor? hope you did not use a universal sensor those are junk, check all your connections and make sure nothing was left unhooked like mass air flow sensor,
Aug 30, 2010 | 2001 Mercedes-Benz S-Class
In my motherboard manual(ASUS P5GV-TMX) specifications there is an entry showing storage/RAID -- 1 x UltraDMA 100/66/33 4 x Serial ATA First are those speeds ?? So does this mean it doesnt support UDMA...
You have 1 IDE connector (1 X UltraDMA) labeled PRI_IDE on your MB that uses a flat ribbon cable to connect with hard drives or optical drives that use that type of connection. The 100/66/33 are transfer rates: 100 MB/s, 66MB/s, or 33MB/s. These connections are quickly becoming a thing of the past and being replaced by the faster SATA (Serial ATA) connections which have transfer rates of 150 MB/s to 300MB/s. Your motherboard has 4 SATA connectors. (4 X Serial ATA)
Thanks for using Fixya.
Oct 09, 2009 | ASUS P5GV-MX Motherboard
Electrical Supplies Logo
16 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
