-   Same as the other guy. Is the change out as simple as removing the bottom case or does the whole computer require complete disassembly starting from the top down? Thanks for any help.
-   yachtpro
Acer TravelMate 225X solution: The battery type CR2032 (Lithium, 3V, 20mm/3.2mm) is the same as mentioned in solution #1 but you must use a cell with connected wires and a 3-pin connector. It is hard to buy. A workaround is (1) to use the battery with connected tabs or (2) the battery holder (maybe BH1060 or similar). Original wire and connector from old battery must be cut out and soldered to new battery tabs or holder pins. Remember polarity - note the wire colors.
The battery position is under keyboard in the central position between the PCMCIA slot and the CD-ROM slot. Remove the strip cover near the display, slide the keyboard in the direction of display and lift it up.
I am looking for a TRUE desktop-replacement.
I am looking for a quad-core min 4. GB of DDR3...
(More)
I am looking for a quad-core min 4. GB of DDR3 RAM.
I also want a better GPU then just the intregrated one so that I can truely play games hi-res, just search me the best laptop you can find, but not from dell, that includes Alienware.
Thanks in advance
