Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Blower motor fault
How do i find out if it the condeser/ballast unit (i think it its called that) or the motor that needs replacing when the motor i s wired up an plug is put in it trips the electric but when disconnected machine works fine i ask so i can find out which part i neeod to buy thanks
  • makiva Dec 28, 2007
    i checked the brushes and they were fine but the motor still boes not work
  • 57 Answers
YOUR PROBLEM SEEMS TO BE A FAULTY MOTOR EARTH LEAKING IF THE CONDENSOR WAS GONE IT WOULD BE BULGED
Posted on Jul 16, 2008
Have an older Coleman mobile home furnace (Mdl 8665D766). Both blower fan and booster motor work fine; however, during heating, booster motor will keep constantly running after system cycles through
The booster motor? Do you mean the inducer motor that helps push the exhaust? If the inducer motor won't shut off when the thermostat is satisfied and everything else does shut off, it sounds like the contacts on the relay that powers the inducer are at fault
Feb 03, 2018 | Coleman Heating & Cooling
I have a 2001 alero oldsmobile. I replaced the blower knob, the blower motor an resistor an still my blower knob does not work at all please help!!!
alero's had a persistant problem of ac condesate building up inside heater box and rusting the blower drive motor shaft to the point it wont turn anymore id get a look at this first. if fan wont spin free with your fingers all them other parts arnt going to help you
Oct 24, 2014 | 2001 Oldsmobile Alero
What is a bottom blower? No bum jokes, please! I think it's something to do with engineering, but not too sure.
the bottom blower in a PAC9 is the blower motor that sucks room air in through the bottom vents of the unit through the condenser. this air removes heat from the condeser and is blown out through the warm air vent duct. A common failure on windchaser units is the 'bottom blower squirrel cage' which is a plastic fanblade.
Jan 04, 2011 | Windchaser PAC9 Air Conditioner
My 98 dodge ram van 1500 blower only works on 1,2,and 4 not three and i just replace the blower motor resistor cause it was only working on 4 now im confused some help please
CHECK YOUR SWITCH IF YOUR BALLAST RESISTOR IS WORKING OK (MAKE SURE !!!COULD HAVE A BAD ONE ANYWAY) THE SWITCH IS AT FAULT
Mar 02, 2010 | 1999 Dodge Ram
Have no heat blower motor is not blowing
First check your fuses to see if you have a blown. If not you may have one of two issues. First (and cheapest) is the Heater Regulator this is located within the blower unit and is used to control the blower speed. You need to check the blower isn't moving at all, The regulator will only be at fault if the motor turns. If not the blower unit has gone and needs replacing/ Hope this helps
Dec 17, 2009 | 2004 Honda Civic
Interior heater module?
do you mean the blower motor only works on the fastest setting? and the other three lower speeds do not work at all.
if this is the case then it is a fairly common fault with your resistor pack. its sometimes called a ballast resistor, cheap to buy as well.
to get at it , remove the glovebox (not sure what the americans may call this, the storage container in the passenger side dash board). 6 screws 3 at the top inside and 3 at the bottom outside.
the blower motor will be right in front of you and the the right of the motor (left hand drive cars) you can see the ducting for the air. the resistor pack is located in the wall of the ducting, on the top i think (the blowing air keeps it cool). It is circular in shape with a 4 pin plug. if you turn it counter clockwise about a quater of a turn it should unclip, although it might be quite hard to get your hand on it.
Nov 11, 2009 | 1997 Volkswagen Golf
GMPN 100-4 furnace. Blower motor runs when not calling for heat.
The board is bad. The unit thinks a flame is present, so it tells the blower to come on. Replace the board.
Oct 07, 2009 | Goodman Heating & Cooling
Squirell cage blower motor runs all the time
Relay. You may just have it wires wrong but relays are easy to replace. Rus
Jun 14, 2009 | Coleman Heating & Cooling
THE BLOWER MOTOR IS MAKING NOISES AND SMELLS
your bearing failed and is causeing friction replace motor
Jun 05, 2009 | 2001 Honda Accord
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
