Question about Indesit 24 in. DI67 Free-standing Dishwasher
Dishwasher problem dishwasher begins to wash, water flows in, then both first and second green indicator lights flash together and the cycle does not complete. I have cleaned the filters, removed water that's left in the bottom of the dishwasher.
  • Sn00zy Aug 12, 2008
    Can anybody enlighten me to the problem other than a new dishwasher?
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Posted on Aug 08, 2012
2 Suggested Answers
  • 5 Answers
SOURCE: Indesit 24 in. DI67
Hi there
I have had this problem before. If your dishwasher is not level water collects at the front. Try tilting your machine forwards. Be carefull though as water will come out of the bottom. Once you have done this and reset your machine it should be ok.
Posted on Jan 15, 2008
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Wash cycle not completed
Lights 1 and 3 indicate that the filters are blocked.
Check water flows through the spray arms onto the cutlery - indicated by wet cutlery.
If dry - recirculation pump is probably blocked
Apr 06, 2014 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Clean Light blinks, wash cycle does not initiate
The clean light usually will blink due to a failure to heat the water properly. I have put together some information on this and how to reset the machine so it will work again. Follow the link below and let me know if it helps.
May 06, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Indesit 24 in. DI67
Hi there
Jan 12, 2008 | Indesit 24 in. DI67 Free-standing...
Indesit 24 in. DI67 Free-standing Dishwasher Logo
697 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
