Question about Sony Ericsson K510i Cellular Phone
Problem of my phone
My phone hang..then i turned it off by removing the battery. then, when i turned it on it does not continue to the main menu Only the sony ericsson logo appears everytime i open it.
  • Rukirox Mar 28, 2008
    I changed ma sim and when i again swithchd on the phone..only a white screen appeared. and now the phone is not getting charged. I changed the IC but it does not seem to solve the prob.
  • 425 Answers
Hi
most common prob regarding hang ups are hardware failure, usually flash ic or its cpu. try reheating that parts or else have it change...
hope it can help...
Posted on Oct 16, 2007
My Kyocera Event 3g smartphone keeps turning off and on by itself over and over again every time i take the battery out and put it back in i don't even have to press the power button because it turns on by...
Sound like you have to restore the phone and if still persist..phone replacement if battery is good.If you have an SD card in phone remove it please. Make sure your picture and contacts are backed up to SD card. This will take phone back like new.
    • Turn off the phone.
    • 2 Hold down the "Volume," "Power" and "Home" buttons at the same time. Continue holding the buttons until the 3-D Android logo and a menu of system options appears on the screen, and then release the buttons.
    • 3 Press the "Volume" button to scroll through the menu options and highlight "Wipe Data/Factory Reset." Press the "Power" button to select the option.
    • 4 Use the Volume button again to highlight "Yes, Delete All User Data," and then press the "Power" button. The Event deletes all your personal data and settings from the phone and then returns to the first menu.
    • 5 Highlight "Reboot System Now," and then press the "Power" button to restart the phone. After several minutes, the Event starts up and opens the main screen, giving you the option to set up the phone just as if it were brand new.
Feb 10, 2015 | Kyocera Cell Phones
My samsung corby wont turn on,..
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 10, 2012 | Samsung S3650 Corby / S3650 Genio Touch...
My Nokia 5230 when i turn on it will turn off in main menu... what do i do???
Sir please change the battery and then turn on.Then it will be OK.If the problem still continue then go to a near by servicing center.
Apr 05, 2011 | Nokia 5230 Cell Phone
H,i I tried to give a hard reset my phone but pressing the key recovery and has a symbol on the screen, now does not respond, how long should I wait or should it be immediately?
Did you press the MENU.
Follow the following steps:
To reset the phone using phone buttons
  1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds.
  2. Wait for the phone to finish the reset process and then press MENU.
Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, andthen re-install it. After re-installing the battery, turn on the phone.
Mar 17, 2011 | HTC Hero Smartphone
My blackberry 9000 was hang what will i do? when i turn it on it will not push thru to the main menu
hi hsirt_090874 take the battery out of thr phone lrt it reboot. Next you will need to let it booth up. of it can not get pass the mrnu you willneed to ahard reset of the phone. if you can't get to the menu, use the desk top manager and reload the software back on to the phone. go to blackberry .com to get the blackberry desktop manager. hope this help
Feb 28, 2011 | RIM BlackBerry Bold 9000 Smartphone
Master reset code
  • Remove any memory cards that are in the phone (MicroSD, SD or MiniSD), and remove the SIM card, if your phone uses one. Make sure the phone is turned on before continuing (if you had to remove the battery to remove the memory card or SIM, turn the phone on).
  • Select "Contacts" from the main screen of your cell phone to access your contacts list. Go through the entire list, selecting each name and deleting the entry. Consult your cell phone manual to find out where the "Delete Entry" option is located in your Contacts menu (if you do not have a manual use the link in "Resources" to download a copy of one for your phone). Typically, when you choose an entry, the option to "Edit" will appear on the screen. Select that and one of the sub-options will be "Delete Entry." Do this for all of the entries in your Contact list.
  • Open your text messaging (SMS) application on your phone. Most phones have an icon you can choose from the main screen to go to the application (where you can compose, send, or read SMS messages). Press your "Menu" key again (or the key under the "Options" choice on the screen), and select "Delete All." Click on the choice to delete both read and unread messages. When you are done, return to the main menu.
  • Delete all of your media files. Go to your music, video, photo and MMS directories, and either use a "Delete All" option from the menu, or individually highlight each file name, select "Edit" and then "Delete" and remove each one.
  • Open your calendar and clear all of the entries. Make, sure when you choose this option from the calendar edit menu, that you check off the option to remove the calendar history as well, so past events are erased.
  • Open your email settings (where you entered your email address originally to receive notifications on your phone of new emails), and delete the email address you registered.
  • Open your notepad program and delete any notes you may have stored in the memory. Do this for any Voice Notes, if your phone offered this function as well.
  • Oct 07, 2010 | Motorola Mobility W220 Cellular Phone
    Hanging, slow response and no internet access
    Haiz these china Iphones are quite expected to be like that. The main problem is they ALWAYS hang. So maybe refresh it or remove and put back the battery for a few times?
    May 03, 2010 | Cell Phones
    Software hang
    there is two options 1.  Trun off your mobile and remove your battry again turn if on this may fix it.
    2. The other option is more possible to solve it you have to make master reset your mobile it is 100% chances after this your wlakman will start working.
     Remember to safe your all contects and messages all other thing before master reset.
    Hope this will help you.
    Nov 22, 2008 | Sony Ericsson W550i Cellular Phone
    Nokia hung up
    my nokia3230 menu is not opening. But iam able to receive the calls.
    Jul 22, 2008 | Nokia 6288 Cellular Phone
    My Screen Freezes!
    My phone's screen freezes at start-up and I cab't even get to the menu to restome my factory settings???
    Jun 22, 2007 | Panasonic X300
    Sony Ericsson K510i Cellular Phone Logo
    50 people viewed this question
    Top Sony Ericsson Cell Phones Experts
    Computer Repairing
    Computer Repairing
    270rexton
    270rexton
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
