Question about NorStar Meridian M2250 Console Phone
Meridien m2250 wanting to put out a voicemail to everyone in the network
I am looking to put out an announcement to everyone in my building
  • Siobhan Hagan Nov 21, 2013
    sorry should have said by voicemail not on tannoy
How Do I Get A New Voicemail Password?
You must do a factory reset when a password is forgotten.
Sep 28, 2016 | Samsung SGH t340G Straight Talk Cellular...
When somebody is calling me my phone (vtech) has only 4 rings before the voicemail starts for them to leave a message. can i do something to get more than 4 rings before the voicemail starts?
Press SET UP when in idle mode and the system announces the current number of rings setting.
Press right/SKIP or left/REPEAT until the system announces the desired setting, then press SET UP to save the setting and go to the next setting, or press /PLAY/STOP to save and return to the idle mode.
If you need a manual, you can download one at
http://vt.vtp-media.com/ecp/documents/product_Product/55/UserManual/106/CS5121_Manual.pdf
Aug 28, 2011 | Vtech CS5121 Cordless Phone
No one in my work place knows how to work our phones. We use Nortel Networks T7316, it doesn't help that they don't make this model anymore :/. I was put in charge on setting everything up which i've done...
The feature your looking for is custom call routing(CCR). If your using 4 digit DN's then you probably have larger office environment which I'm not sure that a CCR tree will handle efficently. To build your CCR tree, enter into voicemail admin programming, press the OTHR soft key, then the CCR soft key ehn the ADMIN key
enter in a CCR tree number, then press build At this point you would enter in the number of the path you want to build and what it will do. ex. path 1 means when I press 1 on the dialpad I want it to call Mary's extension(transfer, internal, ext 2221) When your finished building your paths you'll need to save your tree.then you'll need to enable the CCR tree under AA,TABLE, Grtg Table:1, then press next til you see CCR tree: none. Press the CHNG soft key then 1 on the dialpad and ok. That will enable CCR tree 1 to work in greeting table 1. Theres a large section dedicated to building and changing CCR trees in the Nortel voicemail manuals so don't be discouraged if you don't get it on your first try. good luck
Sep 10, 2010 | NorStar T7316E Corded Phone
How do i retrieve voicemail messages from the outside?
every phone comes with a code
this code when entered while you hear the message stored in the answering machine, will stop the recorded message and will announce various options that you can choose from to do some task including listening to the voicemails.....
so read the manual to find the way to get the code from your devise, the code can be changed when ever you want
Nov 19, 2009 | NorStar T7208 Corded Phone
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    Lg phone net10 can't access voicemail
    Most voicmail systems can be connected to via land line. You do this by calling your cell phone waiting for it to go to voicemail then when you here the voice you press the * button. It should begin the routine to access your mail. I am not sure that this will result in anything different but it is worth a try.
    Jan 10, 2009 | LG Cell Phones
    Connect the Meridien 2616D to my home phone line
    it wont ever work.this is a nortel proprietary telephone and will only work on the nortel products. there is also issues with voltages etc.you are lucky if you have not damaged the ptt end of your home line remove it as quickly as you can...hope this helps
    Dec 20, 2008 | Lands Phones
    Need Meridian M2250 operating Manual
    the user guide has being downloaded to this site
    there should be no issues..keep in touch
    Dec 11, 2008 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
    Change the voicemail announcement
    Flip open the top cover on the right hand side. Swich the selectors to the same position for the announcement you want to change. Press the change button and then the announce button. Start recording, hit the stop button when complete. The new announcement will automatically play.
    Nov 10, 2008 | Lands Phones
    Please help me
    I have ATT VOIP service. You are probably recording your messages on your ATT voicemail. Change the # of rings for the voice mail to pick to more than the answering machine picks up. You have to get into your account and look for the section that allows you to do that.
    Sep 04, 2007 | Motorola Mobility MD681 Cordless Phone
    Lands Phones Logo
    32 people viewed this question
    Top NorStar Lands Phones Experts
    george  peters
    george peters
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
