Question about FireLite (USBFLB80) Hard Drive
Firelite wont mount on my computer
My Powerbook G4 with OX10 will no longer mount my firelite externel hard drive. It shows up in disk utility but it will not verify and Error: The underlying task reported failure on exit (-9972) appears. What can I do to mount the drive without losing the data that is on it?
  • jran Oct 09, 2007
    thanx fo the info. the io content is dos_fat_32. how do i check the driver for hdd and how do I delete the hdd in device managment?
    Scholar:
  • 113 Answers
Look at its format, (NTFS) or (FAT32)? and check the DRIVER for the hdd to see if it has any complications or errors, this is easyest fixed by deleting the HDD driver in Device managment and then restarting the computer. good luck.
Posted on Oct 09, 2007
SOURCE:
Flasing red light on my firelite smartdisk
restart computer and let me know if the drive shows up might want to plug drive into another port too
Jun 07, 2012 | FireLite Computers & Internet
Cant find the disc on my powerbook g4
STart up your G4 using the OS disc for leopard, but instead of reinstalling the system, go to the menu at the top of the screen and Launch Disk Utility.
You may need to remount your hard drive. The disk utitliy can do this for you. Then it should appear in the disk utillity window. Then you should be able to install the OS and away you go!
May 10, 2010 | Apple PowerBook G4 Mac Notebook
IMac won't recognize firelite external disk
Try to connect it to another computer (Mac or PC).
Disasemble the case, and remove the disk-drive.
Connect the disk-drive as a "slave" in some other desktop computer, and see if the drive is "detected", and if your files/directories are visible.
Apr 16, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
MacBook won't recognize my Lacie Rugged Hard Disk. Disk utility will see it but won't verify it nor will it repair it. says it needs to be reformatted yet it won't even let me initialize it. it is brand...
Is your MacBook as fast as the Lacie Rugged Hard Disk is?
Because solid state drive wasn't available on MacBook Pro at the initial time when it launched. Hard drives on all current Apple laptops are equipped with Sudden Motion Sensor technology. In fact, the Apple laptops that came with Sudden Motion Sensor are: All Intel-based Apple portables such as the MacBook, MacBook Pro, MacBook Air, PowerBook G4 computers starting with PowerBook G4 (12-inch 1.5GHz), PowerBook G4 (15-inch 1.67/1.5GHz), PowerBook G4 (17-inch 1.67GHz), and iBook G4 computers starting with iBook G4 (Mid 2005) have Sudden Motion Sensor technology. You MacBook may not have come with that technology that could be the reason you are unable to connect it.
Sorry mate... too many limitations on
Feb 24, 2010 | LaCie Rugged All-Terrain (301017) Hard...
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
Powerbook G4 Laptop not starting :-(
sotware is awry 1. put in your system disk and restart holding the c key 2. when the screen shows hit continue 3. go to utilities in the header menu 4. select disk utilty 5. select repair permissions 6. select repair disk after the permission repair is complete 7. quit utility go to start up disk  select your hard drive and restart good luck
Apr 01, 2009 | Apple PowerBook G4 Mac Notebook
Apple dard drive
Hi, I'll need more info to help you...
What is the MacOS X version ?
Model of PowerBook, speed, Ram HD Size, DVD?
When was the last time it worked properly ?
What would you say happened to make it lock up like that ?
Did you change anything ?
Are you talking about the internal drive or an external drive... ?
Please advise...
Mar 18, 2009 | Apple PowerBook G4 Mac Notebook
500 GB WD external hard drive not mounting
Just go to the drive icon in the mycomputer and open the drive you can get the files no need to go the utility
Jul 23, 2008 | Computers & Internet
My mac computer do not reades or recognize my external hard drive 60GB smartdisk from firelite
well. Open Disk Utility in the Applications folder under Utilities and see if it shows up and possibly mount it from there. Also open the System Profilier (also in the utilities folder) and check under USB - if that's how it's connected.
Nov 12, 2007 | FireLite (USBFLB80) Hard Drive
FireLite (USBFLB80) Hard Drive Logo
186 people viewed this question
Top FireLite Computers & Internet Experts
Ekse
Alun Cox
Are you a FireLite Computer and Internet Expert? Answer questions, earn points and help others
