Question about GE 24 in. GSD500X Built-in Dishwasher
NO Water Disher sounds like its running but its not getting any water. Yes the water is turned on and when we puleed the dishwasher out th look underneath it, the piping with the teflon tape leaks (a very slow drip)
  • 290 Answers
Check the float under the lower rack. It should move up and down freely and you should hear a click when moving it. This operates a switch that turns the power to the water valve off if it gets to full. If it sticks in raised position or has gotten out of place where it rests on switch under the dishwasher, the valve will not let water in.
Posted on Oct 09, 2007
  • Michael  Lindley
    Michael Lindley Oct 11, 2007
    Just wanted to follow up on your dishwasher problem and see what you found out.
    Thanks/Mike
SOURCE:
Water sounds like its comming to dishwasher after awhile dial turns(timer) disher wsher goes in to dishcharge pumping out water but inside of dish washer seems dry like no wash cycle took place
Look inside the dishwasher for large plastic mushroom-shaped thing in the bottom. This is a float. Sometimes a knife or fork or something else gets in the bottom of the dishwasher and won't let the float go down. When the float is up like this, the dishwasher thinks that it is already full of water, so no water pumps in.
If this is the case, simply remove whatever is blocking the float from going down, and it will work again.
Feb 28, 2011 | Asko D1706 Built-in Dishwasher
My disher washer is making a high pitched sound when I turn it on.
is this a new unit or old one? the high pitched sound is the pump some models make this sound every time they start up. it will make the sound when you start it up but then goes away. try this before you start it run the hot water in the sink let it get hot turn off the faucet then turn on the dishwasher.
Feb 24, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
When I turn on the GE PotScrubber dishwasher with water, water is leaking out from disher please advise. According from one repair guy, it is related to pump issue please adivse
first try to look and see where the water is coming from,,,the bottom of the unit,,,,or the front of the unit...remember the door has a seal all the way around it and it has to seal correct and make sure the latch is all the way in lock postion
Feb 19, 2011 | Maytag Dishwasher
My bosh exxcel disher dose dot fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | Dishwashers
No water coming into washer
Behind the dishwasher there is normally a two little taps 1 for cold water and 1 for hot water, check that the taps are turned the right way and are letting the water into the mechine. post back what you find.
Apr 05, 2010 | GE Nautilus 24" Built-in Dishwasher
The dishwasher has stopped working,there is a water supply & power supply ,cannot see any obivious problem.Bill England
The problem is resolved, i disconnected the water & electricity supplies, cleaned the filters and all moving parts, reconnected elec & water supplies switched back on and the disher worked perfectly and has since.
Dec 07, 2009 | Bosch 24 in. SGS43C12 Classixx...
Disher washer not getting any water??
Hi Harris,
Without a model number, I can't be 100% certain... but it sounds like the flood/safety float is stuck in the ""flood" position. It works by rising and falling with the water level in the tub. If there's too much water, the float will trip a switch and kill power to the inlet valve.
Open the door and remove the lower rack. You should see it right there in front inside the tub. Just lift it and drop it several times to clear it. (It's gotta be all the way down for water to get to the dishwasher)
Now try the dishwasher. Did it get water? If so, please rate this solution. If not write back and we'll go a little deeper.
Tracy
Mar 27, 2009 | Frigidaire Dishwashers
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Dishwasher will not fill with water
make sure you have the door lock on,also make sure there was not a knock ring on the disher washer side,did you remove the disher hose and check to see if hose is clear and disher hole is clear?let me know-mike
Jun 15, 2008 | Sears 24 in. 14181 Built-in Dishwasher
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
127 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
