Question about GE (PSS26MSRSS) Side by Side Refrigerator
Fridge running continuosly
Running continuously
    Champion:
    Habit-Forming:
  • 279 Answers
Thermostat Faulty, i'd say.
Posted on Nov 22, 2013
Printer motor runs continuosly, doesnt stops initialising
Unplug for 2 minutes & try it again. Reboot computer with printer on before trying to use. Still won't work send it for service.
Sep 16, 2015 | HP LaserJet 1020 Printer
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
Frigidaire model frs26rlecsg star and stop continuosly the evaporator fan motor
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
Apr 19, 2015 | Frigidaire Refrigerators
THE FRIDGE SIDE DOES NOT GET COLD. THIS IS A SIDE BY SIDE FRIDGE/FREEZER MODEL: RSH1DTMH
Shut offf power and then after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
Also the blower fan must be checked to work continuosly , check if frost shuts off the fan.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Please check this link for tips to work.
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 27, 2011 | Samsung Refrigerators
Blower fan runs continuously
If you mean that the blower motor runs even after turning the key off...the resister to the blower motor has to be bad to allow this continuosly get current...:)
Dec 15, 2010 | 2003 Chrysler Town & Country
My Whirlpool Refrigetor's copmressor is continuesly on , what is solution , is there is problem with thermostat
Yes since your compressor is running continuosly the first case of the fault could be the thermostat. So you might have to trace the wires to the thermostat including the bimetal / sensor. Check for breaks in the wires as due to frost build up the wires may disintegrate in due time. If not you will have to go with confirming the thermostat. Hope your fridge is working fine otherwise and you have not noticed any other anomalies because if the compressor runs continuosly the cooling can also drop which will therby make a chain reaction for not lettting the thermostat reach the temperature. So inthis case the timer could also be a suspect. So please check all these factors. Good day
Aug 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
Refridgerator not cold enough. freezer is fine but temperature in the fridge is way too warm
If the unit is running continuosly it is probably a shortage of refrigerant,As the last part to get cold with the flow of refrigerant is the fridge,And would need to be leak tested,leak repaired & New refrigerant put into unit. But if the unit is cycling eg running for say 20 to30 minutes and turning off and staying off for too long,It would be advisable to replace the thermostat.Hope this Helps.
Oct 27, 2009 | Bosch Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
