Verbatim usb 320
My hard drive starts for a moment, lights up, I hear it spin then a small click is heard and it stops completely. 1 second later that process repeats. The external is never recognized on my computer. How can I fix it?
    Problem Solver:
  • 20 Answers
Click sound in hdd is mainly comes when media is failed. And if so you can't repair it at home. Don't open it otherwise your data and warranty both wipe.
Posted on Nov 21, 2013
3 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: My computer won't recognize the external hard drive.
The bad news is he's mostly right, not much the average user or lazy technician can do.
The good news is if you handy there's a cheap solution you can attempt, and if it fails several escalating levels of professional assistance you can get.
First, if you're feeling handy and want to try this yourself you can remove the HDD which will be a standard 2.5" or 3.5" harddrive(measure the narrow side).
Second, remove the cables and unscrew any mounting brackets.
If the cables are similar sizes and smooth resembling a USB cable they are SATA Cables and it is a SATA drive.
If one has four cables, usually one red, one yellow and two black and the other is a much wider wafer cable with either 40 or 80 pins it is an IDE drive(which type is of utmost importance in the next step).
Now, go to a computer store, or parts store(no staples doesn't count). Ask for a 2.5/3.5" SATA/IDE hard drive enclosure. I will be an empty shell similar to the one you just took apart.(should cost 20-50 depending on brand and store, I like nexstars myself but brand is not that important).
Take it home and assemble it with your drive inside. Power it up and plug in the USB.
If it works you HDD is likely fine and just the controller board has failed in the other enclosure. If it doesn't you're only out a few bucks and now you know for sure the problem is with the HDD and you will likely require further, direct assistance from a pro like myself.
Either way get back to me and I can bump you along to the next step or pat you on the back for a job well done
Hope this helps FixYa,
Chris
Armor-IT
Posted on Apr 26, 2009
  • 10406 Answers
SOURCE: Verbatim 320 gb usb external
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Hi Guys, you must be getting this a lot, but i am going nuts! I have a Hitachi 5K320 250Gb Harddrive that for some reason I cant get in anymore. I have very important stuff on there that i need for my...
I know it sounds a little nuts but try it with the drive upside down or on either side or on end supported by some books, you can also try cooling it off in a fridge for a while. when a drive starts to go and starts making clicks and vibe noises you have very little time to get everything off. before you try anything make sure you have space to save the files if you do get in.
Also look into Puppy Linux it runs in ram without running the hard drive,
Puppy may be able to read your drive.
I'll check in with you later, off to work.
Regards
TickMagnet
Aug 16, 2011 | Hitachi Travelstar 5K320 320 GB SATA Hard...
How do I safely turn off my Verbatim hardrive when I shutdown my laptop that it is attached to.
In the notification area you will see an icon with the Safely Remove hardware label - click on it; a small window will appear listing the devices connected to the USB ports (your stick included) . Click on the entry corresponding to the stick, wait a few moment to be unloaded from the Windows and take it out. Now you can shutdown safely.
Feb 06, 2011 | Verbatim VER95327 USB Hard Drive
I have a verbatim usb 2.0 1 TB hard drive and I can't disconnect it from my laptop. I get a message- windows can't stop your generic volume device because it is in use. I just installed Roxio for computer...
Look down in the corner, the right corner for an icon that looks like a small drive slanted with a green arrow over the top of it. If you click on this ICON, it will bring up a small window that says safely remove devices, click on your verbatim drive and it will give you a message. If it fails to do this then Ctrl+Alt+ Delete keys pushed all together one time brings up a window with six buttons. Select "Task Manager" and it will allow you to stop certain processes. Look for the Verbatim drive and halt it. Failing this, you can shut the machine down and remove the disk.
Jan 01, 2011 | Computers & Internet
I bought a verbatim 320 model. The blue light flashes on and off but the usb never loads. I can hear the drive wanted to boot but it just flashes on and off. I'ts able to work in my computer if I keep...
It seems that the disk-drive is "dying".
If it works, at least a bit, copy all the files from it onto your C: drive, or burn the files to DVD-writable disk(s).
Then, exercise the warranty to get it repaired/replaced.
Nov 01, 2010 | Verbatim 160GB USB FireLite: The "drive...
Dear Sir I just bought a verbatim 500 GB external
When you press the button it takes a few seconds for the indicator light to come on because the drive is initializing on startup, in other words its starting to spin up which could take a few seconds. Press the button one time and wait 30 seconds to see if its just the delay for the Hard drive to come to speed. And the same for the shutdown it may take a few seconds for it to park the drive and shutdown.
If this helped give a thumbs up.
"Patience is a virtue" I read that somewhere.
Aug 17, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
I've plugged a portable harddrive in and it's not being recognized. It's a Verbatim USB 320. I am on a Toshiba with Windows 7
The USB memory key want to use a drive letter already in use. To fix it ,click on start,right click on My Computer then click on Manage. You may need to enter your password or click on Continue in the User Account window. Click on Disk Management and look for an entry that does not have a drive letter. Right click on the drive and then click on Change Drive Letter and Paths. Click on the Change button and select a new drive letter from the dropdown menu.Click OK in both windows to save.
Regards Bill
Apr 15, 2010 | Verbatim 96823 320 GB USB Portable (Blue)...
Verbatim 160GB Hard Drive won't boot.
Try it on another PC or on a powered USB hub: maybe it's not getting enough power to run.
If it still doesn't work, and you don't hear the drive's spin-up noise, the electronics may be damaged, the internal disk disconnected or the internal power connection faulty.
If you hear the spin-up whirring and then a series of repeated whirrs and clacks, ending after about 30 seconds - one minute, the disk might be damaged. It still might be recoverable if extracted from the case and connected directly to an appropriate hard disk port (a 3.5 to 2.5 adapter might be necessary), but when things go this far, the chances aren't too good.
Oct 27, 2009 | Verbatim Computers & Internet
Verbatim hard drive wont turn on
I have the same problem with my verbatim 1 TB HDD, the only one difference is that i accidentally ejected the USB cable from the hard drive (not from the laptop) and after that the connection was lost of course and the small green light on the front side of the hdd was out. i reconnected the hdd but it never turned on again. the same thing happened to my samsung hdd around a year ago. i will never no more trust in these things they're a kind of ****. (a have notice that i avsolutely took care of both hdd)
Oct 07, 2009 | Verbatim VER95327 USB Hard Drive
I can´t see the portable hard drive unit in my pc
I don't know too much but I may be able to help. I started by closing all applications and then plugged the USB into the port. A few moments later a window opened and when I right clicked it allowed me to make a shortcut to the desktop. The Verbatim icon is now on the desktop and I can click it and it opens. I have Windows Vista and can also open the "computer" option and the hard drive is there - mine shows as drive "f". I hope this helps. I am a good user of the computer but a novice at installing, un-installing, etc.
Nov 22, 2008 | Verbatim SmartDisk Firelite Portable USB...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
