Question about Dell 430-0008 Network Adapter
ME OS Upgraded Realtek 8139 NIC Card issues
Installed the card, checked the software & new drivers, installed the right gateway & IP address but system not able to access my BT Home Hub Router also working my main Vista pc - any ideas welcome
  • 3 more comments
  • james66 Nov 11, 2007
    Works fine on the Vista pc
    The ME pc was set up to use same router via 1.1usb, so should handle the system, just about.
    The NIC, Realtek 10/100, was highlighted by a pc specilaist co to work with ME.
    Where am I going wrong???
  • james66 Nov 16, 2007
    Os,
    Thanks for trying to assist.....
    running ipconfig gave me the ME IP address, no DNS header/listing - but there was a Subnet Mask header & No.& Gateway data
    When i run the msdos IP ping this works fine - 4 sent & recieved, same for Gateway, but www.yahoo.com come back as `Unknown host`.....
    Other
    1 Should I have set up my ME pc internet connection (LAN) to automatically detect settins or a specific config script, or use a specific proxy server (router/hub, I am guessing?) address??
    2 I have disabled WINS Resoloution, is this ok?
    3 I have disabled DNS Config, is this ok?
    Have spent 4 hours running various permutations on set up, nothing doing, hope you can sort me out.
    Additional info, may be of help...:
    a
    I can network the 2 pcs & access files on the old ME pc, via the router/hub in the `my documents` file, from the new vista pc.
    b
    Even when networke is open between the two pcs, when i ping the ME machine, it is `timed out` - no data sent or recieved.
    Hope this helps
  • james66 Nov 17, 2007
    Can access files on the ME pc from the Vista one
  • TMTRESOURCES Aug 02, 2008
    FUN-JIN
  • 21 Answers
    Sergeant:
    Champion:
  • 306 Answers
Works on Vista or not? If it does up grade the other PC to Vista as well .....ME is outdated and soon if not already updates will no longer be provided by microsoft. Most likely ME does not support that NIC.
Posted on Nov 10, 2007
  • cory casper
    cory casper Nov 11, 2007
    on the ME PC click on start, run, type: cmd, hit enter, in the black window that apears type:ipconfig, hit enter, should show 3 address (IP,DNS,Default Gateway) type: ping "IP"
    (eg: ping 192.168.1.1)hit enter....should get 4 packets sent 4 recieved. do it for default gateway as well. if same results type:
    ping www.yahoo.com, let me know what you get.
  • cory casper
    cory casper Nov 16, 2007
    so you can access shared files either to or from the ME machine?
Hello i have d'link airplus g dwl g630 e2 5.0 network card in my other laptop.. it has drivers installed and it connects to network, but i cant get in internet.. it says " the connection has limited...
This happens when the wireless network card fails to get an IP address from the wireless router.
To get the router to issue your wireless network card with a new IP address, right click on the wireless card icon on the task bar and click Repair.
Mar 16, 2011 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Tip
How to Check TCP/IP Configuraitons
The first step in the troubleshooting process is to check the TCP/IP settings. You can check it by using the IPCONFIG/All command on the command prompt. You will see the configuration results. If you see a blank configuration for a card this means then the card is not assigned any IP address. You can assign the IP address manually or via DHCP server. If you are using the DHCP server for assigning the IP addresses then you can use the following commands to get and release the IP address.
IPConfig/Release
IPConfig/Renew
IPConfig/All
If the computer is still unable to obtain an IP address, then there are several things that can causing this problem such as bad network cable or NIC card, DHCP server might have assigned all the IP addresses from its pool, mis-configured TCP/IP settings, incorrect user name and password. You can try to add a new well configured machine to the replace the malfunctioning machine to see if the new machine is working with its settings. Also see if the driver of the NIC is properly installed or not. In case of driver's problem go to the vendor's website and install a new exact driver for the NIC.
on Mar 25, 2010 | Computers & Internet
On a Gateway GT5028 - appears the ethernet card was damaged by power surge. We installed a new 10/100 NIC card but Gateway reports it has a problem. Any ideas? Do I need to disable the onboard NIC card...
No you do not need to disable the onboard Network Interface Card. I would suggest to first start by inserting the new NIC card in a dif. Spot.
If you do not have any other spots to insert it, i would double check to make sure you have the correct driver for the correct operating system that you are running, If you know the model # of your nic card i could gladly get you the correct driver. Let me know if this helps. Thanks
Jun 20, 2010 | Gateway GT5028 PC Desktop
Ip address IR2800
You need to tell copier the IP, gateway and subnet. If you have DHCP set Ip on auto.
Jan 27, 2010 | Sharp AL-1642CS Copier
I need a proper configuration for my realtek 8139 ethernet family NIC. my network diagnostic tool indicated a failure in network adapter but the network connections indicated that i'am already connected....
Does the card have an IP address? From a command window (type "cmd" in the "run" line) type "ipconfig"
If it has any address OTHER THAN one beginning 169.254, it is working. If it has a 169.254 address it is not connected OR there is no device on your network giving out automatic IP addresses. Do you have other computers or devices connected?
Aug 16, 2009 | Computers & Internet
Kyocera 3035 will not print - NIC card red LED flashing
First turn the main Power Switch off, then unplug the network cable from the nic card and leave it unplugged. Then turn the machine back on, when it says ready to copy, press the printer button and print out a network status page. Then hook the network cable back up and go to a pc and click on start then control panel and look for printers and faxes and click on it, then right click on the Kyocera Printer Icon, then click on properties in the drop down then click on the port tab, then click on configure port and check the ip address and make sure it matches the one on the network status page, if it doesn't put in the correct IP Address and apply the change. But if the ip address is right just try printing again. If it prints ok then you are done but if it doesn't try this click on start then run and then type in cmd, then on the screen that opens up type in ping, then a space, then ip address of the Kyocera Machine then press enter, if the Nic card is connecting to the network you should get a reply from the Kyocera's Nic Card if you do then the Nic Card is ok and the Kyocera print driver may have to be deleted and then re-installed. Hope this helps.
Aug 06, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Can´t get an IP valid address on a Toshiba a65 with a Realtek LAN NIC Card that shows well installed, working, perfect a properly reconignized within the system, although there´s no error showing...
Power off your wireless router for 30 secs. and power it up again wait till all the LED are on and functioninh normally.
THEN
Reboot your laptop OR
Right click on the wireless icon and click on Repair - this will force the wireless card to obtain a new IP address from the wireless router.
May 02, 2009 | Toshiba Satellite A65-S126 Notebook
Windows2003 server networking problem
if the pc mother board came with a driver, install network driver/speed.make sure your network card are working very well and you can fastening the speed of the modem before querying it
Jan 31, 2008 | Microsoft Windows Server Standard 2003 for...
Dell 430-0008 Network Adapter Logo
306 people viewed this question
Clive
Clive
Alun Cox
