Sylvania zv420SL8 error code E4
DVD will not record, gives error E4. Used same brand of blank DVD's and worked fine before. Changed brands, tried DVD-RW's. No go. Just need to know what the error code means. Thanks
  • dj103 Oct 11, 2007
    Thank you!!! ...got the unit at a great price so now the choice is fix or buy a new one, but at least I have an idea about what's going on.
    Genius:
  • 1,139 Answers
The error is actually a catch all for three problems or a better way of putting it three problems can generate this error Sylvania requires that you call them with the error code to get an answer on which of the three errors it could be, However I can tell you from working on these units that the issue has to do with recording laser power.
Posted on Oct 09, 2007
SOURCE:
Error message e4 54040990
It may mean that the disk is no longer usable due to scratches or other over-use reasons. If a new disk, it may mean you're using the wrong brand. This machine works on recommended brands, and the brand of DVD+RW that has proven to be workable on this device, and that I use with no problems, is VERBATIM. Hope this helps you solve what's wrong.
Mar 22, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
E-4 54040990 Cannot record on this disc
I had this problem with my Toshiba DVR16 recorder; I was unable to format new DVD-RW discs even though old ones worked fine.
Initially I thought the laser lens was dirty, but no amount of lens cleaning helped. Then I thought the rated disk speed must be to blame, since it was some 4x disks that first presented the problem. But then I tried 2x disks and the problem persisted. So some aspect of the manufacture of these disks must have changed in recent months.
Anyway, the solution I discovered was to perform an 'erase' operation on each disk using a program on my PC called ImgBurn. This is a free program, which can be downloaded from imgburn.com. Just select Tools > Drive > Erase > Quick. Once that's done (it only takes seconds), take the disk out of your PC and pop it in your DVD writer, whereupon it should start its own format routine.
This has worked for me on 3 different brands of disk (Sony, Memorex, Datawrite). Which is just as well, as I was on the verge of throwing the DVD recorder out of the window. Hope it works for you.
<Neil G.>
Sep 29, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Sylvania dvr90vf dvd recorder
Unfortunately without a firmware upgrade the only disks you can use are DVD-R or DVD-RW. The tricky part is that you can ONLY USE 2X speed. Per my conversation with Sylvania there is a firmware update that will allow you to use up to 8x disks, but they are charging $17.00 for it.
Feb 12, 2008 | Sylvania DVR90VE DVD Recorder/VCR
Dvd/vcr recorder/magnavox
my solution may be to never buy this companies products again as I have been having the same issue and since the machine is not been used much and since the disks worked before it really ticks me off. The suggestion noted to my issue recently really didn't seem to be valid due my above statted time period of no problems then sudden isses tends to show me poor quality of equipment by manufaturer.
Dec 06, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Proper connections of my new Sylvania Model ZV420SL8 DVD /VCR recorder playback unit
Connect it to your TV set or cable box, just like you would a regular VCR. Then put a blank disc or tape in to record from either the DVD drive or the VCR drive. There should be an easy dubbing button to record from VCR to DVD. (I don't have this particular machine; I have two other brands of combo recorders, and I use them both like I would a regular VCR. This one shouldn't be any different.)
Nov 08, 2007 | Televison & Video
EWR20V5 DVD Recording Error
The disc must be DVD-R with an R4.7 under the logo and they MUST be 4X or 8X specific .... the cannot be 1X to 8X or 1X to 16X or note up to 16X .... the disc box must state 4X or 8X ONLY .... and yes they are hard to find for sure.....
Aug 24, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Televison & Video Logo
522 people viewed this question
Top Televison & Video Experts
Ekse
