Question about Hitachi 55FX48B 55" Rear Projection Television
Hitachi projection tv troubleshooting - Hitachi 55FX48B 55" Rear Projection Television
Hitachi dlp tv troubleshooting
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Troubleshooting procedure to many popular brand TVs are given.
Jul 17, 2014 | Hitachi Televison & Video
Hitachi tv troubleshooting
Button could also be labeled "wide" "vmode" or similar, otherwise it's in the menus or need a newer remote.
May 10, 2014 | Hitachi Televison & Video
Red screm
http://www.retrevo.com/support/Hitachi-50C10-TVs-manual/id/372ag003/t/2/
Above is your user manual, below is your service manual. Simply perform the troubleshooting procedures and you should be able to isolate your issue. http://www.fixdevice.com/smanuals/file/36453.html
May 29, 2010 | Hitachi 50C10 LCD TV
Auto focus doesn't work
http://www.retrevo.com/support/Hitachi-51F510-TVs-manual/id/371ci865/t/2/
http://www.scribd.com/doc/3401783/Hitachi-Service-Manual-TV-Plasma-42HDT5055-Chasis-PT3G
Above is your service manual, and above that is a user manual. This will assist you no end, this is the manual engineers use to troubleshoot and repair.
May 12, 2010 | Hitachi 51F510 51" Rear Projection...
Troubleshooting
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Mar 12, 2010 | Hitachi 50UX58K 50" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I have no picture, the input or menu doesn't come up when pressed
your tv is loosing the video signal somewhere in the video circuit
for this you may need a good tv tech coming to your home and troubleshoot the tv
Mar 01, 2009 | Hitachi 57F500 57" Rear Projection...
Powering on Hitachi TV
If all you hear is a click and you get no display on the screen, it sounds as though you need a repairman to come out and fix the circuit board. There are several things that cause this symptom on your set but the most common are convergenge amp failure, vertical, or power supply issues. Sometimes as simple as resoldering connections. Other times major troubleshooting and part replacement are required. The repair cost is usually between 175.00 and 375.00 hope you have a trustworthy and knowledgable repair person, good luck, Russmann.
Jul 08, 2008 | Hitachi 50FX20B 50" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 50" TV, no picture, blue light flashes
Replacing the board is much more expensive than repairing it, if the repairs can indeed be done...accordianman
Sep 16, 2007 | Hitachi 51F510 51" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
