Question about Denon AVR-1905 Receiver
Receiver turns on, but turns off after a couple of seconds.
Turns on for a couple seconds and then it says power off and shuts down,what could be doing this?
Try disconnecting each speaker one at a time and see if the amp turns on normally. If it does then you should replace the last speaker wires you pulled. Beyond that, the amp could be bad.
Jan 23, 2016 | Pioneer VSX-D308 Receiver
Why does my receiver turn on for a couple of seconds, then turns off and won't turn on again?
what brand/model? Most likely there is a short in the amp that will need to be repaired
Jul 28, 2015 | Audio Players & Recorders
My Insignia NS-R5100 receiver goes into standby mode a couple of seconds after turning it on.
This happens because of internal overheating - clean the air vents and if you have covered the receiver with a cloth please remove the cloth your problem could be resolved
Jun 21, 2015 | Insignia Audio Players & Recorders
Receiver smoked, sizzeled and then quit
Throw on a couple of shrimp it and let us know when they're ready. You need a pro to look inside it.
Mar 19, 2010 | Yamaha RX-V2400 Receiver
Overload issue
There is a problem in the front end that is allowing some DC curent to flow to the output section. This is detected and the amp goes into protect mode to prevent further damage to either the output section or the speakers. This is likely to be defective coupling capacitors and not an expensive repair. Figure on less than $20 for parts for this repair.
Dan
Oct 14, 2009 | Optimus STAV-3770 Receiver
Intermittent Audio when set on "tuner"
You may have to ( first unplug it from the wall) then pull the top case.
Locate the tuner board , it will be the one with the antenna connections sticking out the rear of the rec'r.
If there's some way to pull the circuit board up and out of a socket/sockets , try that and re-install it.
Other than that I may be able to help you find a good tech.
Jan 15, 2009 | Denon AVR-1905 Receiver
Klh r6200 receiver
Make sure that your speaker wires are not touching and setting off the fuse.
Sep 11, 2008 | KLH R5100 Receiver
POWER OFF alert
When you turn on receiver it will power off. Poweroff shows up and than turns off. if the front panal reads over load the output ic pac001a is defective i had repaired this model before
May 29, 2007 | Pioneer VSX-D710S Receiver
Receiver turning off by itself
I'm having the same problem with my AVR 435. Did anyone ever figure out how to fix this?
May 10, 2007 | Harman Kardon AVR 435 Receiver
Denon AVR-1905 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
