Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster learn button light flashing - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
  • 3197 Answers
SOURCE: My liftmaster pro started to open and then stoped.
The LED flashing 5 times is the code for RPM sensor or motor overload. The RPM sensor is a small circuit board just in front of the motor.
Posted on Nov 17, 2009
Testimonial: "This is the same helpful information I found on the internet. The internet went further to the SOLUTION is to pull the power cord to reset "
  • 3197 Answers
SOURCE: I am not able to program my Homelink (car) opener
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxilary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
If this doesn't work your car and homelink may not be compatible.
Posted on Nov 23, 2009
  • 244 Answers
SOURCE: I programmed 2 new remotes with no issue but,
Try pushing learn button for 6 sec. or more. Next jit for one sec. and code keypad. Does it work? If it does, the remotes may not be compatible with keypad.
Posted on Dec 02, 2009
  • 3197 Answers
SOURCE: Chamberlain Liftmaster GDO just clicks, no lights no open/close
Pull the logic board and check it for burnt or missing traces on the printed circuit. Thunderstorms love logic boards.
Posted on Apr 26, 2010
  • 3197 Answers
SOURCE: I have a chamberlain liftmaster
With all these problems it sounds like the logic board is going bad.
Posted on Nov 26, 2010
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have the Liftmaster Chamberlain Professional Formula I model 102.1499A and for some reason, the learn button will not sync with the homelink on two of my cars. Is there a way to reset the learn button? ...
Here is the information I have for homelink.
Jan 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
I am not able to program my Homelink (car) opener using the Learn button on my Liftmaster Formula I. I used the Rolling Code program. I went through all the steps, indicator light flashed rapidly, I...
Nov 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Liftmaster garage remote keypad that I would like to change the code to. I don't know what model it is, but one code opens one side, and another codes opens the 2nd side
The easiest way to reset the code is to clear the opener memory and reprogram all remotes and keypads. First press and hold the learn button on the back of the motor for 10 sec. Do the same on the other motor. Now you are ready to program. First press and release learn button and then press and hold the remote button that you want to program. The lightbulb on the motor will flash once. For the keypad, press and release learn button. Then press 4 digit code and then press and hold enter until lightbulb flashes one time on motor. Repeat this process for each remote and keypad.
Oct 15, 2009 | liftmaster Chamberlain Garage Door Opener...
Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Clearing codes on liftmaster garage door opener with yellow learn button
you seem to be doing right thing, hold learn button for 10 seconds, this should clear out all coded items; keypads, remotes.
Oct 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Trouble changing passwordon model 940CB wireless keyless entry
easyer then that , you die! Open your garage door, take out the step ladder, a chair or get up on *********** in law's back, (here's your chance to be on her back for a change) press the read button of your unit (motor) a led should light up and on the key pad, key in the new 4 digits code and press enter, the light of the unit should blink javascript:; Post Solution
May 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
46 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
