Question about Sony DCR-HC32E DV Digital Camcorder
Touch control has stopped working - Sony DCR-HC32E DV Digital Camcorder
My controller dpad doesnt work correctly, if I don't touch it, everything works great. but if i touch it, it starts registering left and down continuous pressing in the dpad, and it is not the cable of the...
Not much you can do...try checkingat game stop or gamestop.com for a used controller. Parts are no longer made for the dreamcast unit as it stopped production allmost 8 years ago
Aug 01, 2010 | Sega Dreamcast Console
Touch pad/control board not working?
PART NUMER 8193762 IS WHAT YOU WANT TO CHECK. YOU CAN SEE THE PICTURE OF THE PART AT REPAIRCLINIC.COM
Apr 24, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
The touch control buttons on my laptop do't work
Download and install the latest driver for touchpad from vendor site.
Nov 30, 2009 | Computers & Internet
Touch Pad buttons stopped working
I believe you need to order part #1 in the accompanying breakdown. the part # is 74011539 and it is called control panel/switch assembly. this is the piece with the ribbon cable that plugs into the control unit #10 in the diagram. you can price it out at your nearest appliance parts store. hope this helps.
Oct 26, 2009 | Kitchen Ranges
The ''stop/clear'' and ''clock'' setting feature quit working. Everything else is fine.
This is either a defective touch pad membrane or the entire main control board is not functioning correctly. many times, the unit will have a separate touch control but, most newer models will have the touch pad integrated together with the main assembly. In this case, replace the main touch control assembly.
Jun 09, 2009 | Emerson Microwave Ovens
Bake button and numbers on the keypad have stopped working
HI, this is a touch pad issue but, due to the integrated design of the control board and touch membrane, you will have to replace the entire control board in order to fix this issue. you can purchase this board at the link below.
CLICK HERE
May 20, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Dacor Touch Screen is flickering and doesn't respond to touch
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here.
Mar 31, 2009 | Dacor DMT2420SS Microwave Oven
My touchscreen does not sense touch anymore?
You could replace the battery by going to the A/V store that you bought it from or you could just use a light cloth like that for cleaning glasses and gently wipe the screen. sounds more like the battery or the programming though
Dec 11, 2006 | Universal Remote Control MX-3000 LCD...
Sony DCR-HC32E DV Digital Camcorder Logo
20 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
