Question about Polaroid FLM-2601 Television
Tv comes on and goes right back off - Polaroid FLM-2601 Television
I have a WEGA KDF-50E2000 if power goes out unexpectedly (per storm, or power outage) it won't come back on right away have to wait a hour or two then it comes back on just fine and works ugh
That makes sense. it is allowing the lamp to cool down. To prevent this, please buy a 500Watt UPS and use that on the Tv. then when the power goes out you can shut the TV down properly and then it will turn back on when you want it to.
Jun 23, 2015 | Televison & Video
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Tv goes off comes right back itself
power supply is faulty. Check the capacitors on the power supply. If they are all OK, check the flourescent lamps on the sides of the LCD panel to see if they look black on one end. Hope that helps!
Feb 06, 2014 | Envision Computers & Internet
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
When I turn it on it goes right back off in like 2 seconds- I can hear it come one and start to hear the sounds but it clicks right back off
your high voltage protect circuit is working properly.
take the tv to a tv shop to have them find out the reason for excessive high voltage. Your tv is protecting you from a possible fire.
Jan 26, 2010 | Philips Magnavox 27MS343S 27" TV
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Will not come on
Have you try to replace the power supply? I had the same problem with mine then when i took the power supply out I seen that a cap had busted off the solder joint just resolder it back in place and I am using it right now. its been working for 2 months so far
Mar 22, 2009 | Polaroid FLM-2601 Television
MY TV WILL NOT STAY ON WHEN TURNED ON!
Pull the back off disconnect the CRT Board connected at the end of Picture Tube if TV comes on with sound then you have a Bad TUBE.
Feb 15, 2009 | Sony KP-61V90 61" Rear Projection...
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Polaroid FLM-2601 Television Logo
19 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
