Question about ViewSonic VX2245WM LCD Monitor
Flickering Moniter I got this moniter for christmas '06 and things have been working fine until tonight (10/09/07). I am not sure if it is my video card on the fritz or what. I have two monitors set up and each are running through differnt ports of my computer. Only my viewsonic moniter is the one that is flickering on and off, not the other one. I tried updating drivers for both the video card and the monitor and that didn't help. I tried uninstalling then reinstalling the drivers but that didn't work either. I don't want to lose my dual monitor set up. I am sure if i move my plug from the RGB port to the regular video output it would work since my smaller monitor is in the regular video output and it hasn't flickered. Is this a monitor issue or a video card issue? I am pretty frustrated. Thanks! -Tracy
  • 113 Answers
Re: Flickering Moniter
Take the monitor to a mates house and test it out their, then post here the outcome and i will go into loads of deatil. good luck.
Posted on Oct 09, 2007
0 characters
3 Points
My new 24" AOC LED
The problem may be your computer, plug a spare monitor in the desktop, if you see the same issue, it is the Video Graphics Card in the computer that is causing the problem. However if it turns out the spare monitor is fine, it is your new monitor that has the issues and should be returned for exchange.
Jan 06, 2011 | AOC Monitor
Moniter is flickering, just bought a new video card, have had the moniter for over 2 years , any solution?
You can disassemble it check it for bad capacitors. Other than that you can check on ebay to see if anyone is selling the boards for that model. Sometimes you get lucky and find someone that has the same model with a broken screen.
Dec 02, 2009 | Samsung 225BW Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Moniter is only shows self test e173fpc
It sounds like your video card may be kaput. Can you try another monitor on it? If you use a monitor that you know works, and it does the same thing - then your video card has failed.
Alternately, you can try a different card and the same monitor.
Jun 08, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
Oct 12, 2008 | Proview PL926WBi 19" LCD Monitor
LCD Monitor
use psi slot!
Aug 17, 2008 | Computer Monitors
G Flatron L1515S 15" LCD
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
ViewSonic VX2245WM LCD Monitor Logo
204 people viewed this question
Top ViewSonic Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer Monitor Expert? Answer questions, earn points and help others
