Question about Sony LT29i Xperia TX Unlocked Quad Band GSM Smartphone - Black
Sony lt29 mic not working - Sony LT29i Xperia TX Unlocked Quad Band GSM Smartphone - Black
Sony vaio microphone isn't working. Mic enabled. Drivers are all updated. Any suggestions?
If you plug another mic or even headphones into the mic socket and it works, then your internal mic has the issue. If it still doesn't, you have a configuration issue with the audio driver.
Dec 10, 2013 | Computers & Internet
My sony vaio pcg61611m mic stop working how i enable it?
Open:
  • control panel
  • Sound and Audio devices
  • Audio
make sure you have a microphone listed and that the mic is not muted.
Aug 21, 2012 | Sony Computers & Internet
Hi i have a Sony hdr CX550 handycam camcorder
Most mics will work if the plug fits the socket on camera and it fits on the hot shoe okay, I never use Sony mics on my Sony camera, you end up paying for the name, not the item.
Jun 19, 2010 | Sony Handycam DCR-VX2100 Mini DV Digital...
My sony ericssion w910i mic not working, when i remove the mic the coupper(under the mic) allso removed, what can i do?
It seems that the mic is disconnected from the rest of the circuit. Solder it after a careful check.
Nov 09, 2009 | Sony Ericsson W910i Cellular Phone
Handycam mini dv
I like the Sony VX2100 for the price. It does provide a 3.5mm mic input however be sure that your mic configuration will work with this camera. If you have an XLR mic then you will need an adpater.
The Sony HDR-HC1 also has a mic input but I have had problems capturing good sound from it.
Apr 22, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
K300 sony ericsson mic not working
try change the mike .......... not well contact custamercare...........
Apr 06, 2009 | Sony Ericsson Cell Phones
MY JOB DEPENDS ON THIS! SONY DSR PD 170 AUDIO PROBLEMS
1- Does built-in mic work?
2- Connect direct mic and check sound instead of wireless mic and confirm camera audio circuit.
3- It is Sony professional camera and this should be repaired by Sony qualified technician as you stated that your job depends on it so don't take risk. Attempt of repair by unqualified person is not advised.
Hope this info will help you.
Oct 11, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Calibration mic problems
I had the same symptom on a SONY DAV-DX375. The problem was I didn't have the mic plugged in far enough. The receptacle is very tight even though it is very tiny. Make sure to push plug in until the plastic part is against the front panel. It sounds obvious, but I was surprised how much force it took to seat the plug.
Aug 26, 2006 | Sony DAV-DZ100 System
Sony LT29i Xperia TX Unlocked Quad Band GSM Smartphone - Black Logo
Top Sony Cell Phones Experts
M_Butkus
marykitty63
Nagendra Baliga
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
