Question about Sanyo SR-3620 Compact Refrigerator
My refrigerator is freezing everything - Sanyo SR-3620 Compact Refrigerator
My refrigerator is freezing everything I changed the door gaskets but it us stll freezing sny suggestions
If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
How to Fix a Refrigerator that Freezes Everything - YouTube
https://www.youtube.com/watch?v=gXMJYv6kzKg refrigerator is freezing everything Google Search
Oct 23, 2017 | Refrigerators
Refrigerator freezes everything in the refrigerator
Usually, there is a control knob/dial somewhere in the fridge. Did you try turning it to less power?
Nov 18, 2013 | Dometic RM2652 Refrigerator
JCD2290HES Side by Side Refrigerator: my jenn air side by side is freezing everything an...
i have the same problem i clean the coils and work for two weeks and now is freezing need solution thanks
May 16, 2010 | Jenn-Air JCD2290HES Side by Side...
My refrigerator is freezing everything! We have turned it up as far as we can and still freezes.
I think you have to choose +7 value of your freezing value as per your refrigerator. after that you will be able to still freezes your things.
Sep 25, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerator
need model number cant help if we dont know what meodel it ios but if everything freezes repl the thermostat in refrigerator side
Aug 16, 2008 | Frigidaire FRS266ZDSB Side by Side...
Sanyo SR-3620 Compact Refrigerator Logo
27 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
