Question about Dualit CTS4E 4-Slice Toaster
How to clean the inside of a toaster - Dualit CTS4E 4-Slice Toaster
    New Friend:
  • 16 Answers
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Posted on Feb 08, 2015
3 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: toaster will not heat
If your timer works but no heat and you think you may have goten water inside the toaster area.. chances are you've dislodged the heating element itself. If you shorted it out, you would probably take out your circuit breaker or fuse from the receptacle that provides power. If you are relatively handy, UNPLUG it, then look at where the heating element penetrates the oven compartment to see if it looks normal ( meaning that it is passing thru the wall of the oven ok) then check the other side ( you may have to remove a cover) to see if the wires providing power to that element are still attached. To be honest, I do not know this particular brand that well but it does sound like a fundamental problem that should be easily addressed. Good luck..
Posted on Sep 23, 2008
  • 51 Answers
SOURCE: how can I clean the inside toaster rails
Hi rsands1,
The following link will help you maintain a clean and good toaster,
http://www.pnwb.com/Toaster%20Maintenance%20Parts%20.pdf
Thanks.
Posted on Nov 02, 2008
Model TQ-800H gets toohot and shuts off.
i've found this to be a common problem.... typically, people will clean out the crumb tray at the bottom of the toaster, whilst other crumb bits remain elsewhere inside the toaster, especially close to the heating elements, and alot of newer models today have a safety sensor. try giving it a good thorough cleaning and visual inspection to rule out a little excess building getting in your way...literally. lol. hope this helps
May 09, 2016 | Hatco Kitchen Appliances - Others
The left side of my toaster dosn't work
It's probably one of two things:1) They pressure contacts that engage the electromagnet may have burnt carbon deposits similar to spark plugs. One needs to clean in between the contact (two on each side) while putting slight pressure as the contacts meet.2) The spring mechanism that engages these contacts has snapped at the securing point, thus not able to put enough pressure to engage these contacts that power the electromagnet.
For some reason it's always the left side.
If the toaster is more than 5 years old I would suggest buying a new on , even though these toasters are very reliable. As the crumbs that left inside are so powdery and coats every surface inside, as well.
May 22, 2011 | Tefal TT744115 4Slice Toaster
How do I clean inside the toaster? Not just the trays below but actually within?
You can't clean the inside without a real possibility of damaging the element(s). Hold it upside down over the sink or outside and shake to remove all the stubborn bits. If you poke around inside you will most likely damage it. If you decide to ignore my advice then don't forget to DISCONNECT it first or you risk electric shock!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 15, 2011 | Krups FEP 4 4-Slice Toaster
Toaster will not stay down when you put toast in
I found that the problem was caused by crumbs getting onto the electro-magnets that hold the toaster down, and onto the contacts that supply power to the magnets ant elements. Removing the cover was the trickiest part - my machine had screws with triangular holes in the heads that a normal screwdriver would not fit. I found, however, that these are the same screws as used in McDonalds Happy Meal toys, and you can get special drivers on ebay or from amazon for them. After that it was just a question of cleaning all the contact points inside the toaster (make sure the toaster is UNPLUGGED!!). 15 minute job.
Oct 04, 2010 | Breville CT75XL 4-Slice Toaster
Clean out bottom
Hi .. turn the toaster upside down. There should be an access door there to allow you to clean out the bottom of the toaster.
May 03, 2010 | Tefal Avante Deluxe 2 Slice Toaster
I have a pink two slicer kitchen aide Toaster. The button to pull down the bread to toast will not stay on. Where can I order/buy a new pink one? thanks kathie
Before tossing out the toaster, check on the inside of the toaster, you may have a wire bread closure in there that is blocking the lever.
I took my son's toaster apart when they replaced it, and found a bread closure inside it, blocking the lever. Anything small enough to fall inside could do this too. (The toaster works fine now, and I use it myself!)
Make sure you unplug the toaster first, you don't want to have a "shocking" experience.
Turn the toaster upside down and shake it a few times, over the kitchen sink, and then open and clean the "crumb" compartment.
Sorry to tell you this, but, your toaster is no longer available on the market, you might want to check a few thrift shops in your area...or you can check this link for another model that is pink and a KitchenAid.
http://www99.shopping.com/xPP-toasters--kitchenaid~S-213~OR-0
Oct 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Toaster won't stay down. Toastmaster Toaster
The contacts on my magnetic lock (lever) had some crumbs and build up on it. I had to take it apart but just cleaning it made mine work fine again.
Sep 21, 2009 | Kitchen Appliances - Others
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
Delonghi toaster oven wont turn off
have you cleaned the inside of the oven lately?  With the unit unplugged!
Mar 26, 2009 | DeLonghi DTT900 2-Slice Toaster
How can I clean the inside toaster rails
Hi rsands1,
Thanks.
Nov 02, 2008 | Dualit CTS4E 4-Slice Toaster
Dualit CTS4E 4-Slice Toaster Logo
211 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
