Question about Motorola Mobility RAZR V3c Cellular Phone
Sim card phone got wet....it charges and graphics are fine when turned on, but says insert sim card. got a new one, still the same. dried it a little bit with blowdryer but didn't want to mess it up more. thanks, patti
Buy a bag of ceramic cat litter and put the phone and the sim card in there for a couple of days. It will get the moisture out
Posted on Oct 09, 2007
SOURCE:
My samsung smooth got wet i let it dry but will not turn on
Wet Cell Phone
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front ofa warm fan heater for several hours then reassemble the phone. Hopefully itwill work properly but if does not work then it is faulty and you need a newcell phone.
Jul 08, 2012 | Samsung Cell Phones
LG VU won't turn on with SIM card after getting wet.
Go to your cell phone store and have them try another SIM card.
ATT replaced my SIM for free.
Aug 08, 2009 | LG Vu CU920 Cellular Phone
Samsung G600 - phone asks for sim card but doesnt work when inser
when phones get wet they start to rust from the inside, unfourtunaly this is a long prosses and can take a few months but usually if the phone has got very wet they will not work propley again. they may work temperally but eventually it will probably be completly usless. in future if u wet a phone try drying it immediatly with a hairdryer, inside the battery bit too, this may help the water inside the phone not to cause rusting. sorry about your phone.
May 14, 2009 | Samsung SGH-G600 Cellular Phone
,If the Sim is inserted the mobile will turning off!
Try that sim in another mobile to check if its working.
Try another sim in that mobile, if it's working it's damaged sim card.
If after this the problem persists try clening gently the sim contacts and the sim card reader in the cell phone with a electronics cleaner spray (low thickness). Clean with a dry cloth to dry the oil drops, carefully with a small screwdriver or with the point of a knife lift a little bit the contacts (don't abuse or you'll break them, causing permanent damage to the phone). Make sure it's dry before testing again.
Let me know about the results
May 02, 2009 | Cell Phones
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
Lg 800 was working fine, now it`s not, screen froze, not dropped or got wet, ?? help, please ,regards, tim
Try a new SIM Card in the phone, this is the only way to make sure if the graphics is still ok, otherwise your graphics card in the phone has blown over a period of time. when I say gotten wet it could also mean from your body temperature as well. so make sure the phone is always kept in a dry place. hope this helps.
Jun 06, 2008 | LG Cell Phones
Inserting SIM card in Motorola V3C
Ahh! but there is a slot. Remove the battery and slide in the skinny sim card where you don't think there is space.....voila!
Feb 09, 2008 | Motorola Mobility RAZR V3
Insert SIM Card
you need to get a new main board.....or you can take it to a mobile store tech and have the phone fully service.
But the best solution would be to buy a need mobile....most time when a mobile gets wet......it's more of a 50/50 chance that it will work properly again.
Jan 06, 2008 | Motorola Mobility RAZR V3
Razor phone not reading sim card
Have you tried a different SIM to make sure that isn't the problem? I'd say 3 out of 4 times when the phone gets wet the other stuff works after it dries, but people constantly have problems with reading the SIM afterwards. Hopefully swapping the SIM card out will help, otherwise your only option is to have a repair shop fix it up for you.
Dec 19, 2007 | Motorola Mobility RAZR V3
Cellular phone doesnt recognize SIM after it got wet
dear it happen when mostly connection of sim module is cut of check the connection.
Mar 09, 2007 | Samsung SGH-e317
Motorola Mobility RAZR V3c Cellular Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
