FixYa.com
Tags:
GE Monogram ZISS480DRSS Stainless Steel
FF temp. in the 20's. (by 2 users)
posted by jesus3 on Oct 09, 2007
FF temp. is set at 37*f but temp. go as low as 22*f. Can not reset the temp. Also the touch pad do not respond when I try to turn off unit
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by girardmom, posted on May 03, 2008
Refrigerator stays in 20 degree range and freezes food. Repairman has order numerous parts. Still not fixed. GE service is awful.
Best Solution
posted on Dec 23, 2007
Thanks for Trying (70)
Bob from LI
Rank:Wiz Wiz
Rating: 84%, 397 votes
Unplug the unit for a couple of minutes and restart. If this doesn't fix it, you may need to replace the computer board.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks, but I found the problem long ago. It was the damper open all time and it did made the boar erratic. After replace the damper, the frige work ok.
Can you Help with these Refrigerators problems?
GE Monogram (freestanding) Ice...
Just suddenly stopped making... Answer This...
GE Monogram freezer not...
grid stuck
Trying to remove grid in order... Answer This...
ge monogram side by side fridge
I have a ge monogram side by... Answer This...
Monogram water flow problem
My GE Monogram refer has a... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
